Author Topic: mk1 misfire  (Read 1702 times)
Offline mog
mk1 misfire
« on: 24 October 2003, 12:21 »
87 mk1 gti, 1.8 8v.
just replaced the fuel pump and cleaned out the lines, and all was good.
on the first run the engine would stall if you braked sharply, but that seems to have stoped now, but last night i went for a long drive and on the way out it was all stuttery and felt and sounded like it was misfiring between 2500 and 4000rpm
on the way back it was worse and was stuttering right throughout the rev range. i've done the plugs, dizzy cap and rotor arm recently, anything else i should be checking?
Offline richandhazel
Re:mk1 misfire
« Reply #1 on: 24 October 2003, 14:05 »
What was wrong with your old pump? And did you notice if there was any crud in the inlet strainer to the pump? What condition is your fuel filler neck in?
Basically I'm wondering if you have crud in your fuel tank. Although you've cleaned all your fuel lines out you may find they are contaminated again if you didn't clean the tank out.
Offline danhock
Re:mk1 misfire
« Reply #2 on: 24 October 2003, 15:15 »
Ignition module?
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
