Author Topic: Postcode settings in sat nav  (Read 9187 times)
Offline Jas
Re: Postcode settings in sat nav
« Reply #10 on: 15 September 2016, 18:08 »
I will be taking it back for the rattling door trims they are driving me mad especially the passenger side you can hear it over the radio  :angry:
Mine went in a few weeks ago for that. The black plastic trim needed some packing behind it and inside the door, our VW production line friends had forgotten to put some anti-rattle tape on the bars that go from the door release handle to the locking mechanism. It's loads better, but not perfect. And I rarely have the radio on so it can be annoying, especially with the windows shut.
To be honest it came as a surprise as i assumed golfs were built well, i didn't even bother test driving the car so it was an unwelcome surprise on the way home. I suppose i can live with the drivers side as i can bang it now and again but the passenger side is bad and in my opinion unacceptable, ill see what they say when i take it back which is a challenge in itself as i work away.
Talking of windows do yours go all the way down? The other day i thought ill put the window down rather than closed with the air con on but in the down position the top of the glass protrudes by a couple of cm so its uncomfortable to put your arm on top of the door  :embarrassed: little things i know but annoying all the same  :grin:
Offline cosmos
« Reply #11 on: 15 September 2016, 18:25 »
I wonder if that along with the dipped reverse mirror is the most common thing for customers to go back to the dealer with on a new car?
Both took me a while to figure out. Also how to get the front wipers into service position.
I know it's all in the manual but who actually bothers with them?  :smiley:
Golf GTI PP | DSG | 5 door | Carbon Steel Grey | DCC | Tech Pack | Parking Pack
Offline Booth11
« Reply #12 on: 15 September 2016, 18:29 »
Cheers Booth11 found it  :smiley:
@p3asa i found the dipping passenger mirror in the handbook whilst looking for the nav info  :grin:
Great.  The sun visor rattle Stevie (p3asa) mentions is well known issue, often sounds like it's coming from elsewhere.  Iirc the issue is the vanity light itself.  Test it by holding the visor up against the roof and if it stops then that's what it is.  There is a VW dealer fix for it I believe due to it being such a common issue.
« Last Edit: 15 September 2016, 18:33 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Watts
« Reply #13 on: 15 September 2016, 18:41 »
The window should fully open! Definitely a trip back to the dealer is in order, main VW dealer?
Previously:
Offline Jas
« Reply #14 on: 15 September 2016, 18:54 »
With you saying that ive just gone out to have another go, bare with me on this guys i know im a complete newbie with the golf and i appreciate your help.
If i put either front window down using the one touch method both front windows were still protruding by a couple of cm, with you saying they should go all the way down i pushed the electric window button down again and nothing, after another 2 presses they both went all the way down so again using the one touch method i closed both front windows and lowered them again, this time they went all the way in so no glass was protruding but i could see the top of the glass sat so again after another two presses the glass disappears, this happens every time now which is better than the glass protruding but it still takes 2 further presses to have the glass completely disappear.
Offline itavaltalainen
« Reply #15 on: 15 September 2016, 20:48 »
Have VW finally sorted postcode crap?
Don't mean that you first need to push 'town' or after changing to postcode that it defaults to numbers even though UK postcodes always start with letters?
Offline Talk-torque
« Reply #16 on: 15 September 2016, 21:22 »
The thing with postcode is that it's not intuitive, in that you do not have to set a city. Just go new destination, then country, and postcode is in the bottom left. First part of a postcode defines the city. 🤓
Roger.
Offline Jedi1971
« Reply #17 on: 16 September 2016, 05:03 »
If you start from scratch ie choose country again after choosing Great Britain a little box with pstcde appears in the left corner !
