Author Topic: Wheel Spacers  (Read 9245 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wheel Spacers
« Reply #10 on: 22 July 2016, 12:48 »
That was lowered 50mm, the roll bar now goes under the driveshaft rather than over so problem solved. Don't forget the lower you go the more you'll be upsetting the geometry of the standard wishbones...
Offline paradisiac82
  • 2003 Golf MK4 GTTDI ARL (PD150)
Re: Wheel Spacers
« Reply #11 on: 22 July 2016, 20:24 »
so to go really low, what needs replacing?
Offline lemski
  • 16v
Re: Wheel Spacers
« Reply #12 on: 22 July 2016, 20:34 »
Anti rollbar and links
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wheel Spacers
« Reply #13 on: 22 July 2016, 21:09 »
If you still want the wishbones to sit flat and retain handling then TT wishbones and hubs are required
