Author Topic: GTI MK4 - Strong fuel smell  (Read 3255 times)
Offline Ian1985
« on: 15 July 2016, 10:34 »
Hi all.
I noticed recently that my 2.0L GTI MK4 seems to have a strong smell of fuel coming from the exhaust. Smoke out the back is slightly black aswell.
Any ideas as to what may be causing this?
Thanks in advance.
Offline lemski
  • 16v
Re: GTI MK4 - Strong fuel smell
« Reply #1 on: 15 July 2016, 13:26 »
Lambda sensor reading wrong normally puts engine light on though
Offline Ian1985
« Reply #2 on: 16 July 2016, 13:08 »
Thanks for the reply. I was thinking sensor. No engine light though, I did a high rev yesterday blew abit of black soot out the exhaust.
Offline lemski
  • 16v
« Reply #3 on: 16 July 2016, 13:36 »
Id try lambda definately
Offline Drewtus
« Reply #4 on: 17 July 2016, 14:08 »
mine did this , changed the lambda and all was well ...
Offline itavaltalainen
« Reply #5 on: 18 July 2016, 20:27 »
faults in memory?
measuring blocks look ok?
would look at both before throwing money at lambda...
Offline Dalo Harkin
« Reply #6 on: 22 July 2016, 11:34 »
scan it with VAGCOM and it will also tell you which lambda (front or back) back doesn't really do much except protect the standard cat from damage, front one compensates for fueling etc
