Author Topic: Dashboard Lights, what should I do?  (Read 17476 times)
Offline jaygolfgti
« on: 02 July 2016, 22:11 »
So, I've had dashboard lights on now for sometime. ABS and the swerve sign. My error checker and VW says that it's either a sensor issue or a electrical fault. I've also had the exhaust light come on and off at times, not sure why, but it's fine. I don't know which it is, sensor or electrical fault. So, what should I do? The lights come on and off, but seem to be on far more now.
Offline itavaltalainen
Re: Dashboard Lights, what should I do?
« Reply #1 on: 03 July 2016, 11:52 »
What are the exact fault codes?
And what car do you drive?
Suppose the engine light is because it's chipped (badly)...
« Last Edit: 03 July 2016, 12:05 by itavaltalainen »
Offline jaygolfgti
« Reply #2 on: 03 July 2016, 17:23 »
No, I had the car chipped yesturday and the lights have nothing to do with that. It was done well at Deamon Tweaks.
As for the 00290 is the main code, there is a second too. I'll need to find that again.
« Reply #3 on: 04 July 2016, 21:07 »
What car is it?
Replace left rear ABS sensor for starters.
You got it chipped with Christmas lights on dash? That is a bit like putting granny that moans about her aching hips on steroids to make her do the olympics....
How was it chipped? Full rolling road pre and post adjustment(s) with probe in exhaust? Or generic 'map'?
Offline jaygolfgti
« Reply #4 on: 04 July 2016, 22:23 »
It's the MK5 2006 Golf Gti petrol. The car has been fine since the chip (it's a bluefin chip).
These are the symbols that are showing:
imagehosting
The exhaust light was one but went off since having the bluefin (I think the bumpvale occasionaly creates an error that I had fitted a whole ago, so not worrying about that, it's rarley on).
So, where would I get a new sensor, and how much?
Offline lemski
  • 16v
« Reply #5 on: 05 July 2016, 10:24 »
Abs, traction control and tyre pressure.
Id say you may want tracking doing. If its too far out the the traction control light will be on as its out of parameters.
Offline peteryspang
« Reply #6 on: 08 July 2016, 09:44 »
imagehosting
There should have a sensor in the brake area,  Just pull out and renew it. Most likely the sensor problem.
Offline mwad gti
« Reply #7 on: 10 July 2016, 12:40 »
Have you got a warning on the screen for ABS/esp failure too?
2019 3 door manual GTi Performance in black
Bought 2 years ago as a 1 owner car, FVWSH and 10k miles
It’s a keeper
Offline gazareth
« Reply #8 on: 11 July 2016, 20:30 »
I would start with the tyre pressures first. as we had a polo in work recently with the abs light coming on at 75mph. turned out, someone had fitted the wrong tyre to the o/s/f :grin:. so with that in mind, maybe a really underinflated tyre would have the same effect.
Offline mwad gti
« Reply #9 on: 16 July 2016, 16:12 »
Update?
It’s a keeper
