Author Topic: Any help with a grinding noise?  (Read 2384 times)
Offline Jbrom1992
« on: 13 June 2016, 21:41 »
I've got a MK4 1.8T and have a sort of grinding/whirring noise.
It usually kicks in as I hit 50/60 and then carrys on as I come off the accelerator. Can't feel anything through the steering wheel and no problem changing gears.
Any bright ideas what it could be? Gearbox has been mentioned in other posts, but I'm also thinking wheel bearings? I jacked up the front and there's a little bit of play in the front wheels from side to side.
Thanks very much!
Offline Tezmax
Re: Any help with a grinding noise?
« Reply #1 on: 14 June 2016, 16:04 »
To be honest there`s a huge difference between grinding and whirring. Grinding will end badly unless found soon. Whirring will probably be wheel bearings seen as it starts at a certain speed.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
