Author Topic: Gauges question  (Read 2014 times)
Offline ian007miles
Gauges question
« on: 09 June 2016, 05:16 »
Hi every one I've just fitted newsouth performance oil pressure and oil temp gauges wot sort of oil pressure should I be looking at once the car has warmed up and also wot sort of oil temp should it be at. Thanx in advance cheers Ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline lemski
  • 16v
Re: Gauges question
« Reply #1 on: 09 June 2016, 11:28 »
Oil temp should be around 110degrees from memory
But the cooler the better the oil cooler is working.
Pressure I cant help with though
Offline gazareth
Re: Gauges question
« Reply #2 on: 10 June 2016, 23:51 »
20 psi at idle with oil temp at about 80 degrees I would say.
