Author Topic: Plastic side skirts - take apart  (Read 3754 times)
Offline GeoBog
« on: 30 May 2016, 18:44 »
Does anybody have a clue how to take apart the black plastic trim under the sills? Hope it's the correct name for the part (picture below)
« Last Edit: 30 May 2016, 20:35 by GeoBog »
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline Talk-torque
Re: Plastic sill trim - take apart
« Reply #1 on: 30 May 2016, 19:37 »
If you look at the second photo in this advertisment, you will see that the plastic skirt has slots which must fit over screws fixed into the sill. If that's right, then the plastic skirt would be released by sliding it until the screw heads line up with the wider part of the slots. Don't know which way, though!
Roger.
Offline GeoBog
Re: Plastic side skirts - take apart
« Reply #2 on: 30 May 2016, 23:09 »
Thanks for the link, I have made an idea of how it fits. I have tried to slide the skirt both forward and backward but it won't budge. I believe the skirt is made out of 2 separate parts: an inner part which fits onto the screws as you said and the outer part which clips onto the inner part.
2020 VW T-Cross SEL
Offline p3asa
« Reply #3 on: 31 May 2016, 00:03 »
Out of curiosity Geobog why are you wanting to remove them?
My dealer damaged one of mine and is refusing all responsibility. Its not that noticeable but noticeable to me so its something I might try and change in the future so I am interested if you manage to remove yours.
