Author Topic: Mk7 GTI Wandering Steering (slightly)  (Read 6777 times)
Offline P6GTD
« on: 15 May 2016, 07:13 »
I have run a Mk6 GTD and then a Mk6 GTI over the last few years, both on Goodyear F1 Eagle AS2 tyres all round and they sat rock solid and steered "hands off" straight at speed.
I bought an Oct 13 Mk7 GTI recently (1 owner, 24K miles) and while the handling and ride are better the car requires constant slight steering correction inputs on straight smooth roads.
It has new Conti Sports on front and Bridgestones on rear. I have had 3D 4 wheel alignment done which shows it was pretty much spot on anyway so no difference has been achieved.
The problem is a slight one but annoying as not relaxing to drive on m/way.
Anyone else experience this?
Offline Chief1337
Re: Mk7 GTI Wandering Steering (slightly)
« Reply #1 on: 15 May 2016, 08:44 »
I think I know what you mean. I've experienced this and thought I was going mad. I've personally found this to be at its worst in 'comfort' steering mode where there is more play in the steering (for the same movement). Not so noticeable when in sport or normal steering mode.
No uneven wear (tyres on front and back covered around 10k now) and alignment is fine, pressures are the right values etc.
Offline P6GTD
« Reply #2 on: 15 May 2016, 10:17 »
Thanks for your reply.
I never select Eco and usually run on Standard unless I am around town when it's Sport.
Might try Sport on M/way to see if that tightens it up......but the car ought to be consistent whatever.
Anyone else?
Offline P6GTD
« Reply #3 on: 15 May 2016, 18:55 »
Hmmmmm....OK so I have posted the most boring item in the history of the forum.
Obviously there are only two people who have a problem with the steering issue.
Thank you to my one response.
Still no wiser on my issue with the car.
Online Watts
« Reply #4 on: 15 May 2016, 19:27 »
Hi there P6GTD, peoples may be out and about today as the sun's been out for a change. Patience is a virtue :smiley: There's lots of very friendly and helpful people here in my experience so it's well worth sticking around. I've not noticed anything too untoward with regards to your issue but mine does get caught out on the concrete sections of the M25 and gets very fidgety but on good flat tarmaced surfaces it's absolutely fine. Are your tyre pressures okay? Perhaps a dealer visit is required. Good luck :smiley:
PS - there's nothing more than most people on here like than some great pictures of member's cars :wink: Perhaps add your car's spec to your signature strip?
PPS - do hang around, plenty of good advice to be had on here for all sorts of issues and upgrades etc..
Previously:
Offline kalimon
  • My other car's a van
« Reply #5 on: 15 May 2016, 19:45 »
I keep a keen eye on my tyre pressures and today, my tyre pressure monitor went of for the first time.
It indicated that my nearside front was low.
I've just checked them all now and they were all slightly down but I'm assuming that's to do with tyre temperature.
It won't take much to make your car wander on a straight road so it's well worth checking them on a weekly basis.
If they are all fine and the car is still off, I'd get the geometry checked again :smiley:
5 DR Mk 7 GTI PP
Offline P6GTD
« Reply #6 on: 15 May 2016, 21:36 »
Thanks all, I guess I just saw 200 odd visits to my post and felt ignored!!  :sad:
Yes, as a regular observer visitor to the site since 2011 I know there are lots of nice folk on the forum and I appreciate how helpful most want to be to fellow owners.
My tyre pressures are 100% all the time so that's not the issue.
I can only describe the steering feel as being slightly "sticky" as opposed to the 2 Mk6s which had a smooth feeling to the wheel and were planted.
I will sit back and see if anyone identifies with this.
My suspicion is if I change front tyres in due course this will resolve
Online Watts
« Reply #7 on: 15 May 2016, 22:02 »
I'd still be suspecting the tyres, how about swapping the fronts with the rears to see if that makes a difference?
Previously:
Offline GTI_Ant
« Reply #8 on: 15 May 2016, 22:44 »
If the steering is wandering it sounds like worn wishbone ball joints or shot roll bar bushes. These cars are tight.  Have you checked it hasn't been in an accident?
GTi Clubsport DCC winter pack rear camera
Previous:
7.5R 3dr DSG DPB Prets Dynaudio
MK7 GTI PP Tungsten Silver Manual Nav Dynaudio Winter Pack Park Assist
Offline Bungleaio
« Reply #9 on: 16 May 2016, 09:20 »
Do you have Lane assist? My car feels like it's tramlining at times but it's the lane assist doing its thing
Abarth 595 Turismo + Classic Mini + Triumph Street Triple RS
Did have 3door DBP GTI PP
