Author Topic: Weber 32/34 upgrade - Electrical and start up issues  (Read 8511 times)
Offline gazareth
Re: Weber 32/34 upgrade - Electrical and start up issues
« Reply #20 on: 09 May 2016, 00:47 »
have you checked your cam timing? the camshaft might be retarded by one tooth.
Offline InsightMusic
« Reply #21 on: 10 May 2016, 13:20 »
We now seem to have the timing pretty much spot on which is a huge improvement to the ride! Got her idling nicely and the Weber is performing really well!
We now have a major oil lake however haha
It's coming from the fuel pump where it sits in the engine, as we also fitted a new fuel pump at the weekend. The rubber seal is broken, but there's no replacement part out there to buy brand new? I've bought some high temperature gasket material which I'll use to cut out a new gasket which should sort out the issue (Fingers crossed!). I expected the new pump to come with a rubber mount, but it didn't, however there was a new o ring but it's not behaving!
I was also able to weld up the hole in the exhaust, so overall a productive weekend!
« Last Edit: 10 May 2016, 13:22 by InsightMusic »
Offline lemski
  • 16v
« Reply #22 on: 10 May 2016, 14:05 »
Failing gasket paper. Use high temp sealent. Glads its starting to come together
