Author Topic: HOW TO: Access the MFA Secret menu  (Read 29180 times)
Re: HOW TO: Access the MFA Secret menu
« Reply #10 on: 28 September 2005, 18:47 »
No! I demand you move it back this instant!!  :grin:
Offline Mr Blue
« Reply #11 on: 28 September 2005, 19:23 »
The secret menu is ideal for setting your idle speed  :smiley:
I always useit to set mine
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #12 on: 29 September 2005, 08:30 »
Yeah it's a very accurate for setting the idle!
Also - Decelaration fuel pressure &  Intake Vacuum
Any ideas what the these values should read on a properlly set up valver?
Offline tobz.
« Reply #13 on: 29 September 2005, 09:21 »
Tried this out, pretty cool, I like the fact that the mpg reading is instantaneous rather than an average. However the speedometer setting doesn't seem to work on mine it just displays 955 all the time??? This was the setting I was most interested in as my momo wheel obstructs my view of the speedo. Does this setting work for everyone else???
You got any pics of your dad's split ?
« Reply #14 on: 29 September 2005, 09:37 »
on another site it lists it as 'rpm engine' and says it shows the actual rpm of the engine?  Could it mean the idle rpm?
Offline wellfan
« Reply #15 on: 29 September 2005, 22:21 »
Please explain. What is 'Land Code' and what do the rest of the readings indicate. I have managed to access the secret menu but it means f... all to me.
« Reply #16 on: 29 September 2005, 23:17 »
I have managed to find an old copy of the website, I'll update when I'm not drunk and tired  :grin:
Judderi
« Reply #17 on: 11 July 2006, 15:57 »
Are you still drunk and tired?
« Reply #18 on: 12 July 2006, 08:25 »
Well I've sobered up and had some rest, here's the cached version I found:
MFA position 1
Default: Engine Code
1. Country Code
2. Road RPM??
3. Upper RPM
4. Lower RPM
5. No Value
6. Display test
MFA position 2
Default: Program checksum
1. Intake vacuum
2. Real time RPM
3. MPG
4. Speed impulse
5. Oil Temp
6. Outside Temp
