Author Topic: R32 full FIS help...  (Read 4436 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: R32 full FIS help...
« Reply #10 on: 08 April 2016, 18:32 »
Thanks Neil I should have all I need now but I'll double check once I get the Bora sport clocks in the car they are destined for and get back to you
itavaltalainen - yes just flashed the full FIS R32 file to the Bora sport clocks, swap foils over and remove/cut the centre warning light panel out to clear the full screen. Then flash the Bora sport clocks with the appropriate half screen file and use the old R32 warning light panel in them with a bit of sticky tape :wink:
To help I rigged myself up a bench flasher in the shed so I didn't have to keep swapping them over in a car
