Author Topic: Bought my first mk4 golf  (Read 249572 times)
Offline Rhyso
Re: Bought my first mk4 golf
« Reply #190 on: 01 May 2016, 21:34 »
You could try fitting the gasket from the Ibiza 160 diesel
Its essentially a blanking plate but with a small hole in it.  Cost about £3 from a dealer
Cheaper than a remap until you can save your pennies for an egr delete kit and a remap  :smiley:
Offline lemski
  • 16v
« Reply #191 on: 01 May 2016, 22:15 »
Thats a top tip
Offline paradisiac82
  • 2003 Golf MK4 GTTDI ARL (PD150)
« Reply #192 on: 02 May 2016, 09:46 »
ok, that sounds good, will this affect anything that might throw up an EML?
Do you have a part number? have looked online and cant seem to find any that don't list themselves as 'blanking' even though they have a tiny hole in the middle
Offline Rhyso
« Reply #193 on: 02 May 2016, 09:50 »
It's designed not to throw an EML but I can't guarantee that
Nope sorry. A Google search will throw it up though. Try Seat Ibiza egr gasket or along those lines
« Reply #194 on: 02 May 2016, 10:09 »
http://www.ebay.co.uk/itm/Gasket-Cable-AGR-valve-SEAT-ALHAMBRA-ALTEA-AROSA-CORDOBA-EXEO-IBIZA-INCH/371566253464?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D36381%26meid%3D79c7e72893cc4562b2ed5394adff096e%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D301886387557 looks like a pretty big hole or http://www.ebay.co.uk/itm/SEAT-EXEO-IBIZA-ALTEA-LEON-TOLEDO-ALHAMBRA-EGR-BLANKING-PLATE-1-5MM-STAINLESS-HD/331800987224?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D36381%26meid%3Dd7879094600744a4af4d7f9031321983%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D152012828266 with a smaller hole?
Offline Rhyso
« Reply #195 on: 02 May 2016, 10:20 »
2nd link. First one is just a standard gasket  :smiley:
« Reply #196 on: 02 May 2016, 10:21 »
Ok might order one of them then. Will try to remove the inlet manifold and give that a clean first.
Offline Rhyso
« Reply #197 on: 02 May 2016, 10:29 »
Clean both at the same time otherwise you won't really see the benefit of doing just the manifold. EGR is only held with on with 3 bolts  :smiley:
Offline lemski
  • 16v
« Reply #198 on: 02 May 2016, 10:32 »
I might haveto do this instead of a delete pipe. Keep it looming factory
« Reply #199 on: 02 May 2016, 18:12 »
EGR is pretty new I think, less than 8 months old
