Author Topic: Bought my first mk4 golf  (Read 249576 times)
Offline paradisiac82
  • 2003 Golf MK4 GTTDI ARL (PD150)
Re: Bought my first mk4 golf
« Reply #160 on: 25 April 2016, 08:18 »
What do you wanna know from graphs. You hit 350ft bl of torgue. Id definately say its a pd150
Just if everything looks ok, like is it boosting when it should, as much as it should etc
Offline lemski
  • 16v
« Reply #161 on: 25 April 2016, 08:26 »
Looks alright to me. But ive not got another 150pd to compare the graphs to.
Specified inlet pressure and actual are very close together wich would say the engine is doing what itshould be.
It tails off and picks back up but im guessing thats when changing gear or haveing to slow down
« Reply #162 on: 25 April 2016, 09:35 »
Yeh had to slow down a lot (and change gear a fair bit) as I don't know of a long enough quiet road to test on :(
Offline Rhyso
« Reply #163 on: 25 April 2016, 09:36 »
You need to do one constant run in 4th gear and just graph that
On the face of it things look ok but just post constant runs from 1500rpm to the redline (or as close as possible) and only that; makes it easier to read! :)
If you can't do it in 4th gear then 3rd will be fine
And take the torque figure with a pinch of salt; standard they are approx 250lbs ft
« Last Edit: 25 April 2016, 09:38 by Rhyso »
« Reply #164 on: 25 April 2016, 09:59 »
not really the roads around here to get that kind of data :(
Offline lemski
  • 16v
« Reply #166 on: 25 April 2016, 21:32 »
Still impressive for a oldish diesel.
Settled its Def a 150 though
« Reply #167 on: 26 April 2016, 18:25 »
ok, so this is my 3rd gear logs, didn't make it to redline as ran out of road
« Reply #168 on: 26 April 2016, 19:49 »
And here are some new pics now its on the road. Needs new front wings and a good wash.
Offline lemski
  • 16v
« Reply #169 on: 26 April 2016, 19:59 »
Thats a nice colour
