Author Topic: Bought my first mk4 golf  (Read 246707 times)
Offline Rhyso
Re: Bought my first mk4 golf
« Reply #130 on: 23 April 2016, 07:49 »
Can you get a wider angle of it??
Offline lemski
  • 16v
« Reply #131 on: 23 April 2016, 11:32 »
Def need a wider angle. Wheres it located?
Offline paradisiac82
  • 2003 Golf MK4 GTTDI ARL (PD150)
« Reply #132 on: 23 April 2016, 15:47 »
Offline lemski
  • 16v
« Reply #133 on: 23 April 2016, 16:00 »
Thats a breather. So must be a flap to open close it when needed.
What a strange setup.
« Reply #134 on: 23 April 2016, 16:02 »
So its meant to look like that? Not meant to be connected to anything?
Also...
can anyone point me into what this means, then can fix the fuel gauge issue lol
« Last Edit: 23 April 2016, 16:04 by paradisiac82 »
Offline lemski
  • 16v
« Reply #135 on: 23 April 2016, 16:10 »
Should be connected id have though. Check round the boost pipe. Wont be far if its there.
Fuel sender working or not.
Sound like a wire broke making it short to ground
« Reply #136 on: 23 April 2016, 16:13 »
Oh don't like the sound of broken wires :(
Offline lemski
  • 16v
« Reply #137 on: 23 April 2016, 16:14 »
Might not be when you lift carpet. Could be the connection loose
« Reply #138 on: 23 April 2016, 16:17 »
Ok will have a look. The garage said they didnt even notice the float (im guessing this is the sender) even being on the fuel pump, would this cause the same error?
Offline lemski
  • 16v
« Reply #139 on: 23 April 2016, 16:44 »
Floats in tank. Should be on the lift pump. 4 torques hold it in place.
Once you have the lift pump out youll see it. Might be the wire in there
