Author Topic: Bought my first mk4 golf  (Read 246671 times)
Offline lemski
  • 16v
Re: Bought my first mk4 golf
« Reply #100 on: 22 April 2016, 16:54 »
Hmmm. Sounds like the lift pump in tank isnt working. You can check via vagcom. Canbus wont let you just multimeter it.
Offline paradisiac82
  • 2003 Golf MK4 GTTDI ARL (PD150)
« Reply #101 on: 22 April 2016, 18:02 »
how do I check in vagcom (im using registered version of vcds lite not vagcom)?
« Reply #102 on: 22 April 2016, 18:38 »
Here are measuring blocks at idle that had readings. Can't see anything thats measuring the boost though.
« Reply #103 on: 22 April 2016, 18:42 »
Looking at that its showing as an AJM engine, have I been coned?
Offline Rhyso
« Reply #104 on: 22 April 2016, 18:57 »
Sticker in the service book or white sticker in the spare wheel
AJM is the 115
ASZ is the 130
ARL is the 150
« Reply #105 on: 22 April 2016, 19:01 »
AJM is the 115
ASZ is the 130
ARL is the 150
It says ARL and reg shows up as ARL (PD150) but like I said, those pics from VCDS Lite are showing engine code AJM so I'm fearing its had an engine swap :(
Offline lemski
  • 16v
« Reply #106 on: 22 April 2016, 19:03 »
Aslong as turbo and such are cchanted wouldnt matter. Could have had an ecu swap as thats what vcd would pic up.
Perform that test on first start of the day and post up. Then can see if it shows where the problem lies.
« Reply #107 on: 22 April 2016, 19:06 »
What test? Is there any way of finding out (is there any physical differences) which it is? seems very quick for a 115bhp but never driven one so it might be :(
Offline Rhyso
« Reply #108 on: 22 April 2016, 19:11 »
AJM is the 115
ASZ is the 130
ARL is the 150
There should be a tag on the engine itself by the cam cover i think
Does it have pipework coming from the top right as you look at it, down the drivers side and then across the front of the engine towards the passenger side?
If so then its the 150 as it has a frount mounted intercooler  :smiley:
See this link for a picture
http://racingbazar.hu/alkatresz/komplett_motor/arl_motorkod_1.9pdtdi_150le_motor_elado_golf_iv_bora
« Last Edit: 22 April 2016, 19:13 by Rhyso »
« Reply #109 on: 22 April 2016, 19:13 »
AJM is the 115
ASZ is the 130
ARL is the 150
Yeh it has a front mounted intercooler, its def a 150 from factory, would a 115 not fit the FMIC from a 150? I'm just thinking if it has been swapped and they could of left that in place then maybe they have. IF not, and say it is something like the ECU being swapped, will that give me a 115 map?
Yes it looks like the one in the link sent, what does a AJM look like?
« Last Edit: 22 April 2016, 19:16 by paradisiac82 »
