Author Topic: Auto lights delay  (Read 4385 times)
Offline GM
Auto lights delay
« on: 10 March 2016, 21:34 »
Could anyone confirm if there is a bit of a delay between starting the engine and the auto lights coming on? My previous two cars have had auto lights and both came on immediately as soon as the engine started, but the Golf's come on after around 20 seconds, which just seems a bit odd? I find myself waiting to drive off waiting for the lights to come on!
Offline Diehammer
Re: Auto lights delay
« Reply #1 on: 10 March 2016, 23:30 »
Mine come on straight away as long as it's dark enough.
Golf GTD MK7 5 door Manual, Carbon Grey, Keyless Entry, Rear View Camera.
Ordered 26/02/15  Build Week Confirmed 24/04/15 (BW21) Stage 5a 19/05/15 Stage 5b 21/05/15 Stage 5c 29/05/15 Stage 6 02/06/15 Stage 7 04/06/15 Pick Up 06/06/15
Offline TwoSheds
« Reply #2 on: 10 March 2016, 23:36 »
No delay on lighting up if dark enough..
Offline dv52
« Reply #3 on: 11 March 2016, 07:12 »
 So - the Light sensor  that's bonded to the windscreen is the device that initiates the "auto" function. It basically has two reference levels as set by the factory: The turn-level which is nominally 500 lux during twilight and the turn-off level, which set-to  200 lux during dawn. The driver has the ability to alter the turn-on level around the threshold setting via the MENU (early, normal, late) and further modifications to this threshold are possible with a VCDS cable.
The response of the light sensor is deliberately dampened so that the lights don't suddenly turn off/on when the car travels through a bright/dark patch, but when the ignition is turned-on for the first time there is a vey short wait time for the electronics to stabilise before the Auto function works. The wait time is dependant on the ambient light conditions at ignition turn-on - but generally it isn't long - in my experience
Don
deliberately "dampened" to ensure that
103TSI Highline ROW (my13)
Offline Gingernick
« Reply #4 on: 11 March 2016, 08:53 »
same on mine, they are slightly slower to turn on than my previous Gti, but I have already got used to it
dont seem to see the calibration 'dance' because of the slight delay though!
3dr Gti, manual, tornado red, performance pack, dynaudio. gone now
5dr GTi, manual, red, Performance pack, dynaudio
going
5dr Gti, Manual, performance pack , indium grey (for a change!)
Offline ajmoir36
« Reply #5 on: 11 March 2016, 17:56 »
Mine come on if I open the door if its dark enough, they stay on all the way through starting the car. Unless of course I mess about for longer than 30 seconds. There is a setting in the menu to adjust the sensitivity.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Mark V GTD
« Reply #6 on: 11 March 2016, 18:28 »
So many strange things about the Golf 7 electrics - at least on mine.
My car would only do the 'dance' if the light switch was left on Auto...
Offline GM
« Reply #7 on: 11 March 2016, 20:18 »
Thanks for the replies. Interesting. What I'm talking about is get in the car in the dark, light switch is in 'Auto' position, start the engine, put it in gear, go to drive off - no headlights. Wait a few seconds, headlights come on. Seems to be the same time that the head unit springs into life. Also noticed that the passenger airbag off lamp in the middle of the dash seems to stay on for quite a while. Bizarre.
Offline Mrparkuk
« Reply #8 on: 11 March 2016, 20:29 »
I have the same effects. Also takes same amount of time for the internal fan to light up / activate.
Current-Jan 2017 M140i, auto. Mineral Grey. ☠😈
Gone-mk7 golf Gti PP, Carbon Grey, 2015 specification, 5dr.
Offline Talk-torque
« Reply #9 on: 11 March 2016, 20:38 »
Passenger airbag light does stay on for a while. I've always accepted that as normal - I don't even look for it to go out.
My headlights come almost immediately after I turn on the ignition, if the light is low enough. Always worries me, as I was taught to start the engine, before turning on the headlights, to put less strain on the battery. I have to consider that the car and it's systems have been designed to do this, so I leave my lights in auto. Always ready to drive off as soon as the engine has started. You must have something not quite right.
Roger.
