Author Topic: Passenger window regulator  (Read 4400 times)
Offline Mageemagoo1971
Re: Passenger window regulator
« Reply #10 on: 04 March 2016, 21:44 »
Thanks for your help
« Reply #11 on: 04 March 2016, 23:03 »
Would I. Just need to replace the one in the door that doesn't show as opening on dash display as it's same door as regulator was attempted to be fixed
« Reply #12 on: 04 March 2016, 23:36 »
+ have u a link
Offline itavaltalainen
« Reply #13 on: 05 March 2016, 08:39 »
I do have a link.... but it's in the language of Volkswagen.
VCDS measuring blocks:
http://golf4.org/Datenbank/Schluessel.html#microschalter
Instructions on how to change switches (watch out there are different versions of locks, some have an additional switch):
http://www.motor-talk.de/forum/golf-4-tueraggregatetraeger-abdichten-schloss-mikroschalter-tauschen-bericht-anleitung-t5033806.html
There are a few different version of the locks, some have up to 5 micro switches in them:
One needs to be physically broken out of the lock plastic, new one glued in to secure it.
If it's the glued in one (no 5 in image above) then RS components part number 823-5217 is the correct one.
Others are 823-5239 or 823-5241, depending on their position on the PCB (they are left or right angled connections).
« Last Edit: 05 March 2016, 09:05 by itavaltalainen »
