Author Topic: Golf 7 PLA retrofit ABS code guestion  (Read 2608 times)
Offline cebbes30
« on: 22 February 2016, 07:44 »
Hello,
I have a guestion about the PLA in my golf 7
PLA working but i have a litte problem!
Whe the car rols back on a neutral gear my PDC wil activated automaticly??
I dont think this is normal.
Can anyone help me with the right code.
See the movie shows the problem
https://youtu.be/YuUIPIP03jY
Before ABS 03 code
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Revision: 00000000    Serial number:
   Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F300280028C0
   Shop #: WSC 00028 028 00024
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 7DEDE93FBDF1976A7486B79-8028
No fault code found.
After code to PLA
   Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F30028F02AC0
   Shop #: WSC 12345 123 123465
   VCID: 7DEDEE57BDF1976A7486B79-8028
I think this is the byte guestion, but i dont now which one be the correct.
Please help?
« Last Edit: 22 February 2016, 16:02 by cebbes30 »
Offline cebbes30
Re: Golf 7 PLA retrofit ABS code guestion
« Reply #1 on: 24 February 2016, 00:33 »
Today I did a test drive with a car at the dealership with Park Assist and onlty with park pilot.
The PDC does not come on When the car rolls back on a neutral shift.
I Have made changed in the byte 26
01FA6AA120212A6C0377060401CB2580560454C06080A4F30028 F0 2AC0 changed the F0 to 50 and the pdc sensor front comes on when i drive forward.
When i roll the car back on a neutral shift the PDC wont come on?
So i think on byte 26 and 27 i need to change bits.
vcds shows no information about byte 26 and 27
Please can somone help me with this.
Offline Mk7-GTD
« Reply #2 on: 24 February 2016, 07:59 »
Doesn't the car need to be in reverse gear?
Offline cebbes30
« Reply #3 on: 24 February 2016, 10:40 »
Yes and a dont now what i need to code.
Offline itavaltalainen
« Reply #4 on: 25 February 2016, 16:49 »
Is there anything on your car that was actually factory fitted?
You must have spent more on trying to retrofit things now than it would have cost to sell yours and buy one shiny new with all sparkles ;)
Rear parking sensor do come on if you start to roll backwards. I often need to get stuff out the boot before I park properly, reverse the car, put it in neutral and turn engine off.... then only turn ignition on and release hand brake and let it roll back using gravity. Parking sensors start beeping...
