Author Topic: Golf MK4 1.4 Won't Start (EPC LIGHT)  (Read 7372 times)
Offline barrym381
Re: Golf MK4 1.4 Won't Start (EPC LIGHT)
« Reply #10 on: 28 January 2016, 16:14 »
Do you know where abouts on the gearbox and how I get to it?
not sure on your car  :smiley:
Offline Aharding1994
« Reply #11 on: 29 January 2016, 13:17 »
Check all fault codes and this is what came up... 18011,16705,16955,00668,00532,01330,00562,01176,01330,00562,01176,01331,01332,01359,01333,01334
Offline itavaltalainen
« Reply #12 on: 31 January 2016, 10:16 »
Check that the connection on the central electrics are all pushed in firmly. If this does not help and you don't have ground issues I would take the CE out and have a close look at it. Possibly something burnt out.... or you have a leak on engine room bulkhead and water in it!!
Once you think you found reason then delete all fault codes and drive a short distance and see if/what comes back.
« Reply #13 on: 02 February 2016, 06:47 »
How do I know if there's water in the baulkhead?
« Reply #14 on: 02 February 2016, 06:48 »
Could it have something to do with the crank sensor? As the exhaust has a leak would it vibrate and maybe bust it?
« Reply #15 on: 02 February 2016, 16:26 »
Just take the central electrics out and see if wet.....  :rolleyes:
« Reply #16 on: 03 February 2016, 07:03 »
The ecu you mean?
« Reply #17 on: 03 February 2016, 09:03 »
No, the CE (central electrics), i.e. fuse box / relay carrier under steering wheel / at door sill.
Although there is another under bonnet too.
« Reply #18 on: 06 February 2016, 08:08 »
That's all fine not wet
« Reply #19 on: 07 February 2016, 05:19 »
Bumo
