Author Topic: Battery charging  (Read 18304 times)
Offline clubsport
Re: Battery charging
« Reply #10 on: 23 January 2016, 20:42 »
The best trickle charger I have by far is an accumate, even better than my 3 x Ctek, it has various charging leds.
You don't need to much information to see of a battery is usable or not.
Offline JamesR27
« Reply #11 on: 24 January 2016, 08:46 »
Hi James,
What sort of usage does the car get once started?
Does it get a good run of steady revs for a good duration before you switch it off again? The alternator should have no problem recharging if it's given the chance to.
It can vary, but since mid December
250 mile round trip to Cambridge
1 week and a bit later a 100 mile trip
Then a few runs of about 10 miles or so over Christmas and a 50 mile run.
Another run of about 30 miles 1st weekend of the year
Then last 2 weekends another couple of 10 milers.
I know the last bit is not massive amounts and with the dark days it's a lot of running with the lights on etc.
Mk 8.5 Clubsport Pure White, Queenstown, DCC.
MK 7.5 R Pure White, Pretoria Silver, DCC, Rear Camera.
Gone - MK 7 GTI Carbon Grey, Rear Camera, Service Pack.
Gone - MK 6 GTI  Reflex Silver, Monza Shadows, RCD 510, Rear Camera, Bluetooth, Tyre Pressure Sensor, Xenons Convenience pack, Service Pack :)
Gone - MK 5 GTI Reflex Silver, Monza II 18's, Luxury Pack, Mulitchanger
Offline dv52
« Reply #12 on: 30 January 2016, 22:33 »
 Need to be real careful when hooking-up any sort of battery charger on a mk7.
Most (all?) mk7s have a battery monitor which sits on the negative terminal of the battery (see pic below), The purpose of the battery monitor (it's part of the power supply LIN bus) is (amongst other roles) to keep a history of the electrical current that is used/inputted) to/from the battery. It provides most of the basic data for the calculation of what VW calls the System Voltage. System voltage (not battery voltage) is what the control modules use when making decisions related to the vehicle's rail-volts.
Anyhow, it's important when charging a mk7 to INCLUDE the battery monitor in the charging circuit. This means that battery chargers should not be connected directly across the battery (i.e. positive-to-positive and negative-to-negative)
The correct way to charge a mk7 is to hook the positive lead of the charger to the battery positive and the negative lead to the special lug that is near the battery terminal (see picture below) - not to the negative battery terminal. If this isn't done the battery monitor is by-passed and the charging current is never recorded!
Don
103TSI Highline ROW (my13)
Offline GeoBog
« Reply #13 on: 30 January 2016, 23:15 »
The above is not valid just for mk7 or VW. Other manufacturers use similar devices. Even in the car charger manual says that it can be connected to the battery while in the car but to connect the negative lead to a GND bolt/screw on the chassis instead of the battery negative terminal.
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
