Author Topic: door lock not catching  (Read 5496 times)
Offline Scottymk4
Re: door lock not catching
« Reply #10 on: 17 December 2015, 16:17 »
I guess I will need the door lock module, do you know how hard these are to replace? do you need to remove window ?
Offline barrym381
« Reply #11 on: 17 December 2015, 16:22 »
cant see it being hard prob best to take window out the way  :smiley:
Offline baker1983
« Reply #12 on: 17 December 2015, 19:51 »
I've had plenty do this across the VAG range. It will be the latch! I've lubed them before and got them working again but doesn't always work and if it does only normally lasts a short time.
Genuine latches vary between about £100 and £150 ish.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 20 December 2015, 20:21 »
Door latch is integral with the module and will cost you around £170 these days...
Offline Scottymk4
« Reply #14 on: 21 December 2015, 10:59 »
Wazzer can I just get one from a scrappie ?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 21 December 2015, 20:16 »
Yes mate, green (later) modules are said to be less prone to failing although it's not unheard of
3 and 5 front door modules are the same, just the cable length is different but these can be swapped
Offline Scottymk4
« Reply #16 on: 22 December 2015, 10:50 »
thanks wazzer, mines is a 3 door, do these modules need coded in ?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #17 on: 22 December 2015, 20:48 »
Nope fit and go :afro:
Offline Simeon
« Reply #18 on: 24 December 2015, 11:09 »
Before you do all that, try adjusting the hook bolted on the pillar, these are adjustable and get pushed in by the door latch over time. Slacken the bolts, move towards the outside edge a bit, tighten and try the door. Small adjustments should get it working Ok, just fixed a door and boot on two of my cars this way.
Offline Scottymk4
« Reply #19 on: 26 December 2015, 10:31 »
a wee update, if i slam the door shut while using my foot on the bottom of the door it closes fine so I guess the door is sitting out at the bottom, how can I fix this ?
