Author Topic: November map updates  (Read 9301 times)
Offline phazer
Re: November map updates
« Reply #10 on: 01 December 2015, 18:55 »
I extracted the lot. It works it out ok. It's the slowest update to apply so far though.
Offline karlak
« Reply #11 on: 01 December 2015, 18:57 »
Hmm,, That is what I did, but it still doesn't see this update.  Previous ones were no problem.
Ordered 06/01/14.  5DR GTD DSG, Red. Park Assist | Rear Camera | Keyless entry | Dynaudio | Winter Pack | Pro Nav.
Offline p3asa
« Reply #12 on: 01 December 2015, 23:07 »
It didn't see my update either so I took the folders out and put them in the root and it worked no problem.
Offline mcmaddy
« Reply #13 on: 03 December 2015, 06:51 »
Either extract or unzip the downloaded file straight to your SD card or straight to a folder and then just move the files to you SD card.
Offline Sootchucker
« Reply #14 on: 23 December 2015, 07:41 »
HI all, bit late to the party on this one, but I've just downloaded the full 22gb for my Nav Pro, and when the zip file was extracted, I noticed it created two folders:
MIB I
MIB II
Never seen this before, I assume as my unit is a MIB I (Sept 2013), I just put the contents of that folder on to the root of an SD card and ignore the MIB II folder, or do I copy the lot to an SD card ?
Offline fredgroves
« Reply #15 on: 23 December 2015, 08:50 »
Just place the contents of the MIB1 folder into the root.
Its annoying that you have to download both versions - especially as its so chuffing large.
Offline Watts
« Reply #16 on: 23 December 2015, 10:25 »
Does anyone know how much it costs for the VW pre-loaded SD card? I'm not mentally equipped to cope with "roots" and files and don't have any suitable equipment for adding stuff to an SD card. If it is expensive then I'll either not bother or the cost may be enough to encourage me to learn how to download. I have the standard nav which I rarely use and when I do, I usually just end up shouting at it!
Previously:
Offline p3asa
« Reply #17 on: 23 December 2015, 10:43 »
MIB I
MIB II
There seems to be a couple of different ways to navigate (excuse the pun :grin:) to the right file to download. One gives you the option of 3 head units with their size displayed for you to choose and the other just goes straight to "Full download" or "download smaller individual segments"
Both though are 21.7Gb for the Nav Pro, which I'm sure its been that size all along so it looks like when its getting unpacked it somehow splits the file into both MIBs which is a bit strange. Also I see the Nav Pro doesn't have a MIB II to select.
I wonder if they've recently changed the files as my Nav Pro downloaded didn't give me a MIB I or MIB II folder.
Offline p3asa
« Reply #18 on: 23 December 2015, 10:53 »
I don't even know if they do pre loaded cards. When i was trying to get our Audis firmware updated which was done by SD Card they wanted to charge me an hours labour at £133+ VAT just for sticking a card in  :undecided:
Its really simple just get yourself a card reader for a couple of pounds like this
Download the files you need to your PC
Extract them
Copy over to your memory card using the memory card reader above
Put it into your car and the jobs done  :laugh:
Alternatively if you PM me your address I'll send you the files you need on a SD card and just put it in the car.
Offline fredgroves
« Reply #19 on: 23 December 2015, 11:33 »
Yes, when the MIB2 stuff was actually in people's new cars :)
22gb is a bit mickey taking really - that's beyond even a large download, that's mental sized.
