Author Topic: Alloy damage  (Read 6508 times)
Offline mullermn
Alloy damage
« on: 09 November 2015, 12:12 »
Thanks to a kerb buried in leaves and bad judgement on my part I scratched one of my alloys this weekend  :sick:
Can anyone tell me what type of repair this would need and how much I should expect to pay, please?
Is there any harm in not getting it fixed straight away? I wasn't sure if the damage might make it more prone to any kind of corrosion.
Thanks for any help, guys.
Offline mk7gti
Re: Alloy damage
« Reply #1 on: 09 November 2015, 12:37 »
Its so small get some multi grit sandpaper and spray lacquer from halfords. Job done..
MK7 GTI - Deep Pearl Black - Standard Spec - Ordered 10/12/2015.
MK7 GTI - White - Standard Spec - Service Pack - Collected 11/09/2013.
Offline GatsbyIII
Re: Alloy damage
« Reply #2 on: 09 November 2015, 12:47 »
Agreed. Barely noticeable.
Current: 2015 MK VII GTi Performance/Nav 3Dr Manual | Pearlescent Black | Dynaudio | Sunroof | Parking Pack | Keyless | Rear Privacy Glass 90%
Offline coogy
Re: Alloy damage
« Reply #3 on: 09 November 2015, 13:08 »
Had my GTI only a couple of weeks and managed to catch my rear drivers alloy in a notorious car park. To say I was "annoyed" would be putting it quite mildly.  :angry:
I have a quote from Lepsons to refurbish, though I'm worried the damage is quite deep. Any experiences on this?
https://drive.google.com/file/d/1glQzfU04wEJ5k0urBGcD72FjNTxrIVw_SQ/view?usp=sharing
https://drive.google.com/file/d/1rfmVuNi2pmfgeqUBjGe4NvO_l5wJZUPXtQ/view?usp=sharing
https://drive.google.com/file/d/19Cv5C7kH6SCbDMkE8JP3Jk0xEOZlMH28xA/view?usp=sharing
Offline joe6
Re: Alloy damage
« Reply #4 on: 09 November 2015, 13:37 »
Happened to me with my MK 6. Also quite deep. Good diamond cut repair and not too expensive. There is a limit to the number of repairs on a wheel as some material is removed each time. See the thread: http://www.golfgtiforum.co.uk/index.php?topic=274931.0
Offline coogy
Re: Alloy damage
« Reply #5 on: 09 November 2015, 13:50 »
Wow, OK, that repair is quite impressive. Thanks! :)
Offline wakey
Re: Alloy damage
« Reply #6 on: 09 November 2015, 15:09 »
It will look sh!t though  :smiley:
MK7 Golf R. MK5 Golf Ed.30
Offline GatsbyIII
Re: Alloy damage
« Reply #7 on: 09 November 2015, 16:13 »
Not once it's covered in cr@p - those alloys are approaching mine for the amount of muck on 'em  :cool:
Offline GeoBog
Re: Alloy damage
« Reply #8 on: 09 November 2015, 22:51 »
^ that is true. Also the lacquer will wash off after a couple of car washes as it doesn't stick well to bare metal. From factory the spokes are diamond cut, then are painted in chrome silver prior to being lacquered for a better bond of the coat to the alloy surface.
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline dubber36
Re: Alloy damage
« Reply #9 on: 10 November 2015, 09:11 »
I'd leave it. Just blob some wax on it to stop corrosion every other week or so. You could spend £100 on a refurb plus the hassle of logistics only for the same thing to happen again at any time.
If the damage was more than that, I'd fix it, but it's not a show car, it's a car that gets used to do the job it was intended for. You have to ask yourself, if you were buying it as a used car with that minor scuff on it, would it put you off? Would you get it repaired then? Probably not. You are annoyed with yourself now and want it perfect again, but give it a couple of weeks and you'll not be as bothered.
