Author Topic: My GTD soon departs after a happy two years, is it time to get a Golf R ? R mpg?  (Read 12429 times)
Offline monkeyhanger
mpg is relative to how you drive it. Unless you gave the GTD a nun's run-in, if your trips have you average 43mpg in the GTD, i'd expect about 25mpg if I was you. I averaged about 48mpg in the GTD I used to have, now its around 31mpg in the R. Short trips are around 28mpg and longer ones (my 20 mile commute) you are talking about 32mpg. The R has a big penalty for cruising at 80mph as opposed to 70mph due to the lower gearing. The difference in mpg between 70 and 80mph cruising in the GTD is negligible, in the R it's the difference between 30mpg and 36mpg.
As someone that has come from a long line of VAG TDIs, the R is an amazing car - mine has been a bit troublesome, not for number of faults, but the number of visits to the dealership per fault before they got fixed.
Offline AdmiralGant
Thanks for the replies all, better than I was thinking then for the R and quite right - perhaps I should give the GTI some thought, but the sound of the R seems very additive and I am not sure the GTI is as good??
Think I could live with 25mpg  :smiley:
Fleet
On Order - BMW 330d M Sport with M Sport Plus pack, voodoo lights, adaptive cruise, dampers - Battleship
Decommissioned 20/1/16 - GTD Mk 7 DSG 5dr Carbon Grey, ACC, Winter Pack, Class - Pocket Battleship (Flagship) - commissioned 21/1/14
Seat Ibiza FR TDI 130, Flame Red, Class - Frigate - commissioned 01/09/07
Suzuki Jimny 1.3 JLX+, quasar grey, Class - destroyer - commissioned 30/11/08
Suzuki Bandit 650, red, Class - covette - commissioned 01/09/05
Offline remlapeel
No it's not. I had one and traded it in for an R. The GTI is a good car, but the R is a great car.
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
The GTI isn't as quick as the R, with a small spend on a tuning box you could get your GTD running quicker than a stock GTI in gear.
Of course you could buy a GTI and get it boxed or chipped to be a 2WD car with almost the same output as a stock R (think of it as a VW Leon Cupra). Or you could buy an R. More incentives for the GTI at the moment, but around half of the R's premium is mitigated by better residuals.
I had a DTUK box on my GTD and it really gave it a shot in the arm, but the R is noticeably quicker again.
I do a performance test close to home with every car I get, leaving a roundabout slipway at 20mph and accelerating hard to pass a certain road sign and see what speed I am at - I tried this tonight on my R.
140TDI Golf 5 PD= 70mph
170TDI Golf 5 PD= 80mph
140TDI Scirocco CR = 78mph
170TDI Scirocco CR = 81mph
MK7 GTD = 80mph (cold) / 82mph (warm) - the first time I have seen a limit for a cold engine
MK7 GTD with DTUK box (warm) = 89mph
MK7 R (warm) = 101mph (was 97mph when there was only 800 miles on the clock - it has improved with age, or perhaps the new turbo)
I'd hazard a guess that it'd be about 86mph for a warm GTI doing the same.
Offline remlapeel
I had my GTI mapped to 320bhp with revo and in gear it is quick! Quicker than a stock R on a dry road, rolling with decent rubber. Unfortunately that's also the problem. You need all of your ducks in a row to get the most out of it. Throw part worn tyres, rain or a standing start and watch the traction light goes mental.
Traction when standard is alright, but it's a different league.
For me it's like comparing a 2.0L diesel GT to a GTD. The GT is a is a class below, similar to the GTI and R
Offline JoeGTI
Are you a manual or DSG JoeGTI ?? And are you using the RACE setting a lot ??  :smiley:
Mine is a DSG with about 2k miles on it. I do use Race a bit for sure but mostly in Indivudual mode with a mixture of Sport/Normal settings. The DSG in sport mode is fine for 5 minutes but would drive you mad after that. So it's mostly in D or manual.
I tried Eco for the first time on the motorway yesterday. When cruising the difference isn't all that noticeable.
Traction (or lack thereof) is why I chopped my GTD in for an R. Even though my R came with crappy Flintstones, traction when hoofing it is fully taken care of by the haldex system.
Asking 320ps from the stock turbo and clutch on the GTI is asking a lot. The turbos used in the GTI and the R don't seem to have a high margin of over-engineering like the GTD does - by that I mean some people have popped a turbo or cooked their clutch in a GTI/R here and in the R forum, haven't heard of a GTDer doing the same yet.
« Last Edit: 26 October 2015, 06:47 by monkeyhanger »
Offline AdmiralGant
I agree MonkeyH, the GTD does struggle to get its power down on a hard throttle standing start and even worse in wet. I guess the R just leaves the line with no fuss.
My main concern with the R is people saying they get about 20mpg or less, but no one has shouted that out, so sounds another reason to get one.
I see the GTD/GTI now gets sat nav, keyless and heated seats as std, yet the top of the range R still needs all that added as options.
Am I right in saying the R also has no front fogs? Not a major issue, or are they in the headlight units somewhere?
Fleet
Offline Booth11
You'd have to be driving like a nutter to be getting 20mpg or less!
Certainly does get the power down with NO fuss at all.
Yes keyless, nav and heated seats (only on cloth) are all still extra on an R.  BUT, the build week 45 changes some stuff might get included as standard??
That's right, no front fogs on the R. Haven't missed them thus far and well, when you see the lovely deep intakes in their place you'll forget all about front fogs.
« Last Edit: 26 October 2015, 14:05 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Hawaii-Five-O
  • Are we nearly there yet?
Pretty disgraceful to read that your GTD only achieved 43 mpg (long term avg). My GTI DSG is giving me 38.5 mpg (long term avg). Not that far off your diesel!
Good luck with your decision AdmiralGant. Would you consider the GTI (a relatively rare sight on the roads) instead of the R. Runs on the cheaper 95 RON fuel too :wink:
Current: BMW M140i / ZF8 / 5 DR
Past: MK7 GTI / DSG / WHITE / 5 DR
