Author Topic: Merc 312mm 5x112 discs on mk6 gti?  (Read 2017 times)
Offline Dipesh2031
  • Options bae?
« on: 20 October 2015, 10:17 »
Hi,
Was looking at these, they seem up to spec, a way to get just drilled discs on the cheap?
http://www.ebay.co.uk/itm/Pagid-50270-Front-312mm-Vented-Brake-Disc-Mercedes-S-Class-Coupe-C215-W220-/350719976362?hash=item51a88a23aa:m:mMD1VmKU5w5sP50_-t-RAcQ
Only problem I see, is gti discs are 25mm max and these are 28? may need skimming down to 25?
I've seen people use merc rims on golfs, so bolts should be the same etc? I think they look awesome.
or am I missing something huge!
MK6 GTi - Black - DSG - 18' Monza shadow - Luxury Pack - Convenience pack - Park assist - Xenons - RNS510 - Adaptive chassis control - Dynaudio - Bluetooth - Reverse camera - front/rear sensors --mods-- Evoms Intake - Eurojet/stasis Turboback Catless 3" exhaust
Offline mustard
  • Mk7 R
Re: Merc 312mm 5x112 discs on mk6 gti?
« Reply #1 on: 20 October 2015, 15:05 »
I think you will find that the centre bore is larger, the Golf uses 57.1mm, the Merc is 67mm from memory, also the distance from the disc to the wheel mating surface is larger.
