Author Topic: Standard boost pressures? Power delivery / turbo issue  (Read 9336 times)
Offline mrred32
Hi guys, having a little issue with power delivery/accelaration in the GTI (DSG) and wondered if someone could advise.
When cruising everything appears fine however when I boot it the Rev needle begins to rise, then skips and appears to drop (not changing gear). It also happened when in manual and I go down to 3rd - 1200 revs and then boot it. Also there is a noticeable lack of power (accelaration and power delivery feels similar to my old N/A clio)
Thinking maybe turbo related but as my first turbo charged car not really sure what to look for. Tried checking the general area for oil/leaks and can't really hear a whistling noise (tell tell sign of pressure leak I think?).
When hooking up to torque on my phone using obd I find when cruising at 40 in 5th the boost gauge is between 19-27 in/Hg (negative) and when booting it it rises to 17psi and drops very suddenly. Is this normal? I've seen on another forum that it should generally be peaking at 12psi. I'm getting a bit nit picky with issues now as Ive only 1 month left on my manufacturers warranty lol. Cheers in advance.
« Last Edit: 13 October 2015, 16:26 by mrred32 »
Offline mrred32
Re: Standard boost pressures?
« Reply #1 on: 12 October 2015, 19:51 »
Any thoughts? Looks like I'll have to suck it up and pay for the diagnostic at VW :(
Offline PD_GTI_MK6
« Reply #2 on: 12 October 2015, 22:31 »
Sorry I've not idea about this but couldn't you take it to a non-dealer to run diag ?
At least that might be cheaper.
Offline Rhyso
« Reply #3 on: 12 October 2015, 22:57 »
If its still under warranty then you shouldn't have to pay for the diagnostic if the problem is indeed covered under warranty
Offline mrred32
Re: Standard boost pressures? Power delivery / turbo issue
« Reply #4 on: 13 October 2015, 16:27 »
Really? I have like 1 month warranty left but I thought that regardless of whether the component is covered under warranty the standard diagnostic (in this case £99 iirc) would be chargeable
Offline eug2huge
« Reply #5 on: 13 October 2015, 17:09 »
Not really mechanical person but have just upgraded my diverter valve as my car has been re-mapped and it was recommended.
The standard part is ok but apparently it can fail quite easily. Might be worth checking.
Offline Rhyso
« Reply #6 on: 13 October 2015, 18:20 »
I've never paid for a dignostic for a warranty issue
Why not ask the question??? Worse case you are £99 worse off BUT you could have work done which costs hundreds so in effect saving you money. Especially if it goes pop soon after your warranty expires.........
 :smiley:
Offline mrred32
« Reply #7 on: 14 October 2015, 13:03 »
Got it booked in, thanks for the advice. £99 for potentially a lot of work seems pretty worth it.
Mmm I've heard about issues with the diverter valve, I might look into the symptoms of a failed valve as it might be what I am experiencing. Cheers.
Offline chris1h
  • MK6 GTI BLACK 3 DOOR
« Reply #8 on: 14 October 2015, 19:21 »
if you had 1 month left on warrenty you shouldnt be paying a penny for them to be looking at it i wouldnt have thought. I certainly wouldnt be paying a penny!  Should took the car in explained the problem. Said dont give s*** what you need doing diagnostics etc its under warranty you sort it, theres the keys. Dealers are a joke! :whistle:
MK6 GTI - 2011 - PEARL BLACK - 3 DOOR  - 18" MONZA SHADOWS  -  RNS510/DAB  -  ACC  - SUNROOF  -  WINTER PACK  - DYNAUDIO  -  VIENNA LEATHER  - PARKING SENSORS  - BLUETOOTH
Offline mrred32
« Reply #9 on: 17 October 2015, 17:28 »
I did exactly that! Went into VW, they refitted the air intake hoses, checked with diagnostic, recharged the Aircon and got it back to me with no charge :).
I'm pretty chuffed with that, a clean bill of health now ready for my MOT and service next month. Just need to start looking at the extended warranty costs now. Cheers for the advice guys.
