Author Topic: Excessive Tyre Wear  (Read 7634 times)
Offline corgi
Re: Excessive Tyre Wear
« Reply #10 on: 08 October 2015, 18:00 »
The garage (Breese Poole) said there was nothing wrong with the tracking.
How do they know?
They would have to set the equipment up on your car and this would be chargeable.
Typically you can tell if the wear is down to tracking/alignment because the edges of the worn part will have feathering and may appear to be slightly blue... Also, wearing the middle of the tyre would be unusual for poor alignment it would be a strange setup that wore the middle of the tyre - alignment almost always affects one side of the tyre or the other. Without the the OP saying the pressures were checked regularly I would have bet on over-inflation of the tyre in question. I doubt buckled wheels would cause this issue...
To the OP. When driving the car does it drive straight? Does it brake and accelerate in a straight line? Do you feel any unusual tugs through the steering under braking? Does the steering feel over heavy? How is the car on turn in? etc.
Also, how do you check tyre pressures? Do you use your own gauge or the one on the air-line at the garage?
Corgi
Offline DorsetDC
« Reply #11 on: 08 October 2015, 19:03 »
Thanks for the replies in particular from Corgi.  The car drives straight and brakes and accelerates in a straight line and there is no tugging or heavy feeling through the steering and the car seems normal on turnin. I always use a calibrated tyre pressure gauge and check the pressures at least once a month.  My first set of Bridgestones wore out on the front after 11,400 miles but the wear was even on both tyres. It's only the replacement set that I have had the problem with.
Golf R 7.5 Diamond Black, Discover Media Navigation, DSG, Winter Pack.
Offline j033y
« Reply #12 on: 21 October 2015, 16:55 »
My Bridgestones wore down at around 13,000 miles at the front, Replaced with Goodyears which so far have lasted about 16,000 miles.
Wish to god the rears would wear down awful sh!t Bridgestones, so much noise from them, VW refuse to change. I am hammering the car about to wear them down. Was thinking of changing to them on the front and wheelspinning everywhere, however the GTD seems to not be able to fully turn off traction control!!
Offline Gnasher
  • Formerly GnasherVXR
« Reply #13 on: 22 October 2015, 08:15 »
I would have put the part worns on the front anyway to get rid of them quicker - even without hammering it everywhere, the fronts will definitely wear quicker than the rears.
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
