Author Topic: Oil temperature on UK roads  (Read 10673 times)
Offline Norvwich
« on: 05 October 2015, 19:43 »
i have water and oil temp OCD.  :laugh:
Probably the worst thing I ever did was configure the display to show oil temperature... There is far greater chance of me damaging the engine by crashing into the nearest ditch (by keeping one eye on the display)  than cold oil ever could.
However it has got me thinking. In normal driving the oil temp sits at 80-90degc. Spirited driving 95degc, but prolonged motorway driving at 80ish sees the temp at 100degc. Is this similar to others? I don't really have a UK ambient reference to go on, so other users input would help (or make my OCD worse!)
Offline seabrook132
Re: Oil temperature on UK roads
« Reply #1 on: 05 October 2015, 19:54 »
I too always have mine showing the oil temp and mine is exactly like yours. After its warmed up and I'm driving normally (spiritedly) then mine is in the range of 95 - 100. I mostly do motorway driving for 1 and a half to 2 hours at a time so I'd say yours is spot on.  :smiley:
2011 GTI DSG 5dr, Tornado Red, 18" Monza Shadows, Heated Leather, RNS-510, MDI, Bilstein B16 PSS10 Coilovers, Ohlins DCC Cancellation Kit, Audi TT-RS Front Top Mounts, Whiteline 24mm Rear ARB, Michelin Pilot Sport 4, 034 Motorsports Street Density Engine and Gearbox Mounts, Audi R8 Red Coil Packs, NGK BKR7EIX, Millers 5W-40 Nanodrive
Offline Bandit127
« Reply #2 on: 05 October 2015, 20:21 »
There is a property of oils called High Temperature High Shear (HTHS) that fully synth oils do well on. It is tested at 150°C.
I certainly wouldn't worry unless I saw over 130°.
In fact constantly running below 100° bothers me a bit because any moisture in the oil (and you will have some from condensation) takes longer to "boil off". You also have volatiles from the fuel (either petrol or diesel) that need to evaporate off and a warmer oil temp helps with that.
100° for me is simply warm. And more of a target than a worry.
Offline Gaz-M
« Reply #3 on: 06 October 2015, 09:28 »
Yous are obviously pussays, spirited driving easily sees 105 degrees, but never much more.
Offline itavaltalainen
« Reply #4 on: 06 October 2015, 12:10 »
Normal driving it sits at 95, maybe going up to 100 occasionally if you drive long distance.
Slightly faster driving than the limit on motorway will see 105 in my diesel, going up fish hill near Broadway tower gets it up to 115 :D Same if I go to Germany and go on the A3 at night time and max it for a while.
Offline golfhappy
« Reply #5 on: 06 October 2015, 12:57 »
Laughed at that description  :grin:
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline mrred32
« Reply #6 on: 11 October 2015, 08:45 »
Yeah between 80-105 sounds normal for me. I know what you mean though, my mfd almost always has the oil temperature up (or the mpg if I'm feeling lucky).
Even worse now that I have torque on my phone and dash mounted, I've become a proper stats monitoring nerd!
Offline PD_GTI_MK6
« Reply #7 on: 23 October 2015, 13:09 »
I started paying attention to this recently as I wasn't giving it full boot until the red needle was sitting straight up at 90c then I looked at the digital reading on the dash and there's a big difference, that was showing around 50c so it appears to me that the analogue needle reading is totally useless.
Even when the digital reading says 100c the needle is still sitting straight up at 90c.
Is this the same for everyone else ?
« Reply #8 on: 23 October 2015, 13:19 »
Yes, that is because the analogue gauge is the engine coolant temperature and the digital numbers are oil temperature.  :rolleyes:
Offline seabrook132
« Reply #9 on: 23 October 2015, 19:24 »
This ^  :smiley:
