Author Topic: Dsg problems  (Read 1805 times)
Offline Jonny341
Dsg problems
« on: 23 September 2015, 19:29 »
Hi i have a mk6  dsg gti and have been having a few problems with the gearbox. Sometimes it's doesn't select reverse straight away and recently the gear number in the top right of the dials goes off when it doesn't select reverse. I am from Manchester and if anyone can help me please with some feed back. Cheers
Offline Poached
Re: Dsg problems
« Reply #1 on: 23 September 2015, 22:48 »
You''ll need to get it scanned for fault codes to see if any are stored.
On my MK5 I had a problem where the gears on the display wouldn't change (but the box changed up and down fine) and they were just highlighted in red. That problem was rectified with a new gear selector module.
Could be several causes...
Offline Jonny341
Re: Dsg problems
« Reply #2 on: 23 September 2015, 23:00 »
I've had the engine read and there's no fault codes come up, the box changes up and down fine it's just going into reverse and then a slight bang into drive. I've been told the mecatronic unit is going if it's doing this and wondered were to have it  Refurbished. Cheers mate
