Author Topic: US EPA accuses VW of cheating in oil burner tests  (Read 25110 times)
Offline corgi
Re: US EPA accuses VW of cheating in oil burner tests
« Reply #20 on: 01 October 2015, 13:24 »
Update the software on the ECU...
They say that it will not affect the performance... but do you believe them?
Corgi
Offline monkeyhanger
« Reply #21 on: 01 October 2015, 15:03 »
Performance or mpg - i'd expect one of those to suffer, otherwise they'd have not needed the cheat in the first place. Unless they didn't have the tech/knowhow for EU5 that they do for EU6.
Offline dubber36
« Reply #22 on: 01 October 2015, 15:11 »
The mk7 tdi is the ea288, but i've done plenty of ea189s on the dyno generally you just switch off the traction control and once the abs registers the rear wheel speed sensor faults it just powers through.
Chris at CC Tuning mapped my 2011 Passat. To get it to work on the rollers, he went through a sequence of pressing the brake pedal and indicating (or something like that)
Offline GTD_777
« Reply #23 on: 02 October 2015, 10:19 »
I logged a complaint with VW when this news first aired. Had a text to call them yesterday quoting my VIN. They checked and confirmed my car isn't affected. O have therefore asked for this in writing. Can imagine being hammered on the residuals with out that piece of paper.
Suggest you all do the same. They apparently have a list of all the affected VINs so can confirm in minutes.
Offline p3asa
« Reply #24 on: 02 October 2015, 13:05 »
Can you imagine the uproar if people had the BHP or MPG cut by a considerable amount?
Would that not be grounds for returning the car as its clearly not what it was advertised at before buying it?
Offline p3asa
« Reply #25 on: 02 October 2015, 13:07 »
If its now just the know how /software update, you would think they would be altering the cars on the quiet when they were back for service / work done and nobody would know.
Offline p3asa
« Reply #26 on: 02 October 2015, 13:14 »
It is concerning but I'm not sure I'd go to that length.
Audi are in the midst of setting up a self service check which I'm sure VW will be doing the same
https://www.audi.co.uk/content/audi/about-audi/latest-news/volkswagen-group-uk-announces-action-plan-to-modify-diesel-vehicles-with-ea-189-eu5-engines.html
Offline SRGTD
« Reply #27 on: 02 October 2015, 15:53 »
Yes, VW, Skoda and Seat have the same news item on their websites.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
« Reply #28 on: 02 October 2015, 18:24 »
How do you know they didn't?  :whistle:
I'm sure I put it on the forum at the time, but my mpg took a bit of a dive and the car took longer to warm up after my first service on the MK7 GTD.
Offline itavaltalainen
« Reply #29 on: 02 October 2015, 19:27 »
You can already check if your VIN is affected:
http://info.volkswagen.de/de/de/home.html?tab=check-own-car
If you get this as a result then you are NOT affected:
Lieber Volkswagen Kunde,
wir möchten Ihnen bestätigen, dass das Fahrzeug mit der von Ihnen eingegebenen Fahrgestellnummer WVWZZZAUZEP533xxx nicht von der Software betroffen ist, die Stickoxidwerte (NOx) im Prüfstandlauf (NEFZ) optimiert.
If you get this as a result then you got f....d:
wir müssen Sie leider informieren, dass der in Ihrem Fahrzeug mit der Fahrgestellnummer WVWZZZ1KZ9W491xxx eingebaute Dieselmotor vom Typ EA189 von einer Software betroffen ist, die Stickoxidwerte (NOx) im Prüfstandlauf (NEFZ) optimiert. Wir versichern Ihnen jedoch, dass Ihr Fahrzeug technisch sicher und fahrbereit ist!
« Last Edit: 03 October 2015, 15:08 by itavaltalainen »
