Author Topic: Map update & Gps?  (Read 13573 times)
Offline mcmaddy
Re: Map update & Gps?
« Reply #30 on: 10 September 2015, 12:52 »
I know it's a pain in the a4se but at least this way it should get fixed properly.
Offline Optimus prime
« Reply #31 on: 10 September 2015, 13:23 »
VW tech dept have asked for a new gps aerial cable to be run loosely around the inside of the car outside of the trim just to check its not a cable fault.  Although current cable passes all diag tests as new MIB is £5,000 :shocked:  If this fails then a new unit will be fitted.  No complaints from me the master tech involved is excellent but he has to follow the guidelines I guess due to the costs involved.
Re: Map update & Gps UPDATE
« Reply #32 on: 19 September 2015, 13:24 »
Just returned from VW with new MIB fitted quick test on the way home found it to be spot on  :smiley:  Real test will be tomorrow from cold so to speak  :rolleyes:  Anyways unit is running later hardware and firmware than the removed unit but is has 2014/2015 maps installed where as I think I upgraded to 2015/2016?  Won't be doing this upgrade again in case the upgrade caused the issue (not certain but once done cannot be reversed so not risking it  :angry:)
New Hardware is H44 & New Firmware is 0376
My old unit was running H43 & 0362
The service from local dealer has been excellent and being able to email the master tech direct made life a lot easier especially when sending over pics of the issue.
Will update after cold start test......wish me luck
« Reply #33 on: 21 September 2015, 13:56 »
All fixed nav is perfect now excellent service from Chelmsford VW :smiley:
Offline p3asa
« Reply #34 on: 22 September 2015, 16:48 »
Did you upgrade to the new maps?
« Reply #35 on: 22 September 2015, 17:02 »
No just in case it was the maps although doubtful.  As once you upgrade you can't go back
Offline p3asa
« Reply #36 on: 23 September 2015, 20:02 »
Personally if it was me I would be upgrading otherwise before you know it you will be out of warranty and have outdated maps.
I know its an inconvenience but surely with the safety of a warranty behind you, now is the ideal time!
Nobody else has mentioned the same problem after a map upgrade.
« Reply #37 on: 23 September 2015, 20:08 »
What's the rush ? Car is 09/2014 so I have 3 yrs, I will wait for the update in either Nov 2015 or May 2016 & still have 16 months to fix it if needed, could even wait until May 2017.  Yearly updates are usually a waste of time I normally only update every 2 years anyway. I only did this update to see if it would work problem was I did it before I really used the previous maps so couldn't judge if the issue was there before  :rolleyes: :rolleyes:
Offline mcmaddy
« Reply #38 on: 23 September 2015, 20:25 »
You get 5 years map updates not 3.
« Reply #39 on: 23 September 2015, 20:27 »
Oh really that's even better thanks for the info
