Author Topic: Central Locking Issue  (Read 3287 times)
Offline laurenceyon
« on: 05 August 2015, 13:10 »
Hi All
I own a 91' 16V Golf with central locking as standard.
The air tube connecting to the central locking pump has popped off, and I can't find the said air tube to plug back in...
Can anybody shed any light on the whereabouts of these tubes?
Hi my name is Laurence, I'm very much like you. Only better.
Offline laurenceyon
Re: Central Locking Issue
« Reply #1 on: 05 August 2015, 19:47 »
This black/green air tide has become disconnected. Where does it connect back to so my central locking will start working again?
Offline laurenceyon
« Reply #2 on: 05 August 2015, 19:47 »
Offline laurenceyon
« Reply #3 on: 05 August 2015, 19:48 »
Help me. My fuel flap is connected to the central locking and it needs unlocking
Offline sparkplug
« Reply #4 on: 05 August 2015, 20:34 »
surely the pipe it fell off is local to the pump ? i would think in where the cables in your picture go
the fuel flap can be unlocked by reaching in from the rear seat,feel towards the hatchback
slightly behind the fuel flap there is a steel square loop, pull it towards the hatchback it will open
the lock
1986 GTI atlas grey
Offline Steve_B
« Reply #5 on: 06 August 2015, 16:17 »
There's a t-piece connector for the vac pipes about the distance of that pipe away hidden in the rear panel, think it's come off that.
Offline Waspy
« Reply #6 on: 06 August 2015, 16:38 »
Yeah there is, a little green one IIRC. I recently reconnected mine.
Still doesn't work.
Offline laurenceyon
« Reply #7 on: 07 August 2015, 09:17 »
Hi Guys
Thanks for your help.
The T-connector had popped off. I have now reconnected the vaccum pipes and the central locking is working.
However, i've had to disconnect the pump due to some seriously shoddy aftermarket door handles... FML.
Here's a photograph taken from last night, the previous owner had a poor taste in wheel selection (Why would you ever take the original BBS RA's off in exchange for these?) - I have every intention of putting a set of BBS RM's on her.  :wink:
« Last Edit: 07 August 2015, 09:25 by laurenceyon »
