Author Topic: What detailing have you done today?  (Read 1205255 times)
Offline Booth11
Re: What detailing have you done today?
« Reply #1070 on: 30 May 2017, 12:32 »
First go with DAS ,only done back of car for a test with meguires mf kit and then a coat of fusso99 king of gloss
Looks nice and smooth and glossy. :cool:  How did you get on with the Megs MF system?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline hepton
  • 2017 GTD
« Reply #1071 on: 31 May 2017, 09:35 »
not a bad system for first timers, who dont know what pads n polish to buy  :undecided: with good results ,i think i done it right,polish come off with ease, one thing im not sure about is how often to add polish to pads??
Offline Booth11
« Reply #1072 on: 31 May 2017, 10:37 »
After first priming the pad, which you need to do every time you change pads, add a couple more drops of polish after each pad clean (spur).  You only want to add a little once the pad is primed. Regular cleaning of the pad during the course of polishing is critical, to stop pads getting clogged.  For example, I spur the pad in use after every few section passes, as work in 12 x 12" sections, or 18 x 18" max.  So I do required number of section passes, then stop and clean the pad using spurring brush. A soft toothbrush works too,  Just run the brush across the pad a few times with the machine running at speed 3/4, and you'll see them fluff back up, then I add a couple more spots of polish and continue.  I switch to a fresh clean pad (and re-prime) after every couple of panels, or after every big panel, i.e roof, bonnet.
You've probably seen this but is a very useful guide.
http://www.polishedbliss.co.uk/blog/2011/08/meguiars-da-microfibre-correction-system/
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline hepton
  • 2017 GTD
« Reply #1073 on: 31 May 2017, 11:11 »
oops ..thanks for info , ill do it properly next time  :laugh:
Offline Booth11
« Reply #1074 on: 31 May 2017, 14:57 »
 :laugh:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Booth11
« Reply #1075 on: 31 May 2017, 15:07 »
Finally found time to give it a much needed clean after over 3 weeks without.  But had to dodge the rain.
Usual pre-wash, wash and dry regime, followed by coat of wax on bodywork and sealant on wheels.  Part way through buffing off wax, the heavens started to open but I powered on through to the end!
Dirty Prets and tips
Bilberried then snowfoamed
Pressure wash rinse commenced
Pretty clean after rinsing off snow foam, before washing with wheel woolies
Separate wheel woolie for tailpipes and front grill
After the 2 bucket wash....
Prets sealed with C2v3
Tailpipes polished with Mothers
Paintwork waxed with Swissvax Onyx
« Last Edit: 31 May 2017, 19:46 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline gtiaps
« Reply #1076 on: 31 May 2017, 20:08 »
Stunning as usual Rebecca 😆😆
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
Offline Watts
« Reply #1077 on: 31 May 2017, 20:50 »
+1 for that, perfect.
Previously:
Offline Booth11
« Reply #1078 on: 01 June 2017, 17:09 »
Thanks for kind words both.  :smiley:
It was nice to get it looking decent again, of course it's already now covered in a layer of pollen again.  I hate this time if year, but I also love this time of year!
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline gtiaps
« Reply #1079 on: 01 June 2017, 19:13 »
Yeah I know exactly what you mean when I got mine home I washed dried polished and waxed the wife's Scirocco but of course it rained and then both card were covered in wet pollen  :angry:
