Author Topic: 90 MK2 Golf Digifant won't start  (Read 7970 times)
Offline gazareth
Re: 90 MK2 Golf Digifant won't start
« Reply #10 on: 22 June 2015, 23:00 »
have you checked a plug to see if its sparking?
Offline JtheB
« Reply #11 on: 23 June 2015, 19:02 »
Yes the fuel pump is priming and when the engine is turning over there is a smell of fuel and there is no spark...
Offline Brighouse-gti
« Reply #12 on: 23 June 2015, 20:38 »
Hhhhmmmmmmm, coil?
Offline JtheB
« Reply #13 on: 24 June 2015, 07:57 »
I have checked the windings of the coil and that all seems ok...
Offline sparkplug
« Reply #14 on: 24 June 2015, 08:28 »
do you have the feed to the dizzy ?
1986 GTI atlas grey
Offline JtheB
« Reply #15 on: 24 June 2015, 14:19 »
How do I check the distributor and where is the feed? Thank you!!!
Offline sparkplug
« Reply #16 on: 24 June 2015, 17:21 »
the Haynes manual (green cover version) has all the how to test in it
mine is a Kjet so it may be different !
as far as i can remember, with the ignition switched on , you should get 5volts
at the small plug on the side of the dizzy....but please check the manual first
1986 GTI atlas grey
Offline JtheB
« Reply #17 on: 24 June 2015, 20:03 »
Ok. Thank you very much. I will look into it and get back to you 😊
Offline JtheB
« Reply #18 on: 25 June 2015, 18:30 »
Hi. I've changed the engine module and that's not worked. I've also checked the two outer pins and they have 12 volts 😐...I'm at my wits ends 😯
« Reply #19 on: 25 June 2015, 23:07 »
Running out of ideas too. I bought a transparent dizzy cap ages ago for when I was having starting issues, that way I could see that when the engine was turning, so was the rotor arm, and more to the point, that there was a spark at the rotor arm, hence me buying some new leads as I didn't have a spark at the plugs.
