Author Topic: Low fuel warning on Golf R  (Read 5067 times)
Offline monkeyhanger
« on: 06 June 2015, 15:32 »
On the GTD, when I was down to about 45 miles range, I would get the fill-up reminder, but i'm down to 30 miles range on the R and no warnings as yet.
Is this something to do with the R having a bigger tank (55L vs 50), like it gets to zero miles before telling you to fill up because that is the point at which the car starts to dip into the last 5L?
As far as the needle position on the fuel gauge goes, it is exactly on the bit where the white tails off into the fine part of the start of the red zone. It looks like the R has a bigger red zone on the gauge than the GTD does (presumably because it does fewer mpg).
Offline remlapeel
Re: Low fuel warning on Golf R
« Reply #1 on: 06 June 2015, 15:36 »
I thought the red zone was for a gallon of fuel. So would be 45miles in the GTD where as the R will be 25-30. Mine kicked over today at 30mpg
2015 MK7 Golf R 3 door, DSG, lapiz blue, 19" wheels, winter pack, keyless entry, dynaudio and high beam assist.
« Reply #2 on: 06 June 2015, 15:38 »
Maybe i'm 200yards away from a low fuel warning and this thread was for nothing!  :grin:
Offline remlapeel
« Reply #3 on: 06 June 2015, 15:58 »
Interestingly how many miles did you get out of a tank? I got 300miles out of this one
Offline CraigW
« Reply #4 on: 06 June 2015, 16:20 »
My GTI usually gets down to 30 miles range before the fuel light comes on
« Reply #5 on: 06 June 2015, 16:37 »
I'll let you know later today when I fill up, it's somewhere close to 300 miles right now with 30 miles left on the range and no warning as yet. I'm guessing it'll have been around 320 miles to zero.
Meeting mcmaddy later for a bit of VCDS tweakery (knocking the Soundaktor down to 30 or 40%). Any other tweak suggestions?
Offline Damo66
« Reply #6 on: 06 June 2015, 18:00 »
I always fill when it gets down to 1/4..
Beetle (1975)
MK2 Golf GTI 16V
MK3 Golf GTI
Corrado G60
MK3 VR6
Passat Sport PDI
MK4 Golf GTI PDI 150
MK5 GTDI 140
MK5 Golf GTI
MK6 Golf R
MK6 Golf GTD
MK6 Golf GTI Ed 35
Beetle Sport TDI
MK7 Golf GTD
Offline JoeGTI
« Reply #7 on: 06 June 2015, 18:05 »
My favourite one is the full rear brake lights, tweak it so that the whole light cluster lights on braking.
Others...
- fan speed on the climate when in auto
- puddle lights to remain on when mirrors fold
- alarm chirp on lock/unlock
- Increase DRL brightness
Probably loads of others I can't think of.
Offline Mark V GTD
« Reply #8 on: 06 June 2015, 18:57 »
If the low fuel warning light is triggered on the fuel amount remaining then it will be different in terms of remaining range on R, GTI and GTD due to their different consumption rates. Mine (a GTD) comes on at around 45 miles to go.
« Reply #9 on: 06 June 2015, 22:07 »
I was wondering if the R having an extra 5L tank capacity made it behave differently. In all honesty, i'd expect the 3 cars to be calibrated slightly differently on remaining fuel, so they gave a common number of miles remaining on the low fuel warning.
Anyway, as predicted, 100 yards into my journey to meet up with Chris (mcmaddy), the light came on - 30 miles left on the range. I got down past Sunderland and Chris set to work with the changes:-
Soundaktor down to 30%. It's now sounding in Race mode like 100% is for Normal mode. I prefer it this way - enhancing the natural engine sound rather than drowning it out completely. There's something a little unnerving about not being able to hear what is going on with the engine as you're driving it (especially during the running in period).
Coming home lights activating automatically, without a high beam flash.
Volume (Gallons) required to refill.
Had a quick blast up one junction of the A19 and back again with Chris, just to try the soundaktor out at it's new setting.
Then I filled up on the way home, around 10 miles into "0 miles". The car took 53.32L (11.64 Gallons) to do 321.2 miles = 27.6mpg for its first fill - with Shell Nitro + (computer read 28.9mpg "since fill").
Feeling a little wary of having dipped 10 miles into "0 miles", I decided not to chance driving on to the nearest Shell garage, so thought i'd try out Esso Supreme and see what that does for me - might not be a fair comparison, as next week in my new job, my commute is going to double,so i'm expecting slightly better mpg if there are no extra opportunities to put my foot down, and the further running in of the car might also take effect.
