Author Topic: Windows 10 Free upgrade?  (Read 10959 times)
Offline Rhyso
Re: Windows 10 Free upgrade?
« Reply #20 on: 07 August 2015, 08:19 »
Installed it the other day onto my nearly 4 year old Toshiba laptop
Only issue I had was it knocked my screen resolution out but after downloading some updates and a reboot fixed that problem
Its pretty zippy but its just Windows; nothing amazing about it I guess  :undecided:
Apps need work as I tried the Facebook app and half my news feed was missing.......so I uninstalled it
VW BUSH
« Reply #21 on: 07 August 2015, 12:03 »
Messed up my sli config, Nvidea drivers and screen resolution.
Could not get both 780's working without flutter at high frame rates (which I know is an SLI problem) but was absolutely fine before the instal....
Also was using more ram at idle than 8.1/classic shell was using, but I am sure I can dial this out.
Going to have another go this weekend to get it all working as I want before I revert to 8.1 or even further back to 7prof.
At least its not like 8 when it came out....
Offline Devilz
  • Cruisin is not a crime
« Reply #22 on: 08 August 2015, 01:55 »
i did upgrade on my laptop and now i'm stuck with windows which can't be activated. Going to call Microsoft and see what they say. At the moment, its calling my legit windows 8 key counterfeit
to use all the windows 10 features, I must activate windows.
VW BUSH
« Reply #23 on: 09 August 2015, 22:10 »
got it all working in the end after about 4 hours
Now using opera and have all live feeds firmly removed or turned off where not.
Offline Organisys
  • Old and Slow...
« Reply #24 on: 04 September 2015, 14:17 »
Windows 10 out, Linux Mint in.
 :cool:
Offline tedvarrick
« Reply #25 on: 18 September 2015, 19:19 »
For thoses of you running windows 10 you may or may not know about windows 10 privacy issues.
from techrepublic
One of the biggest worries, though, is Microsoft's policy on disclosing or sharing your personal information. The following is an excerpt from the privacy policy:
"We will access, disclose and preserve personal data, including your content (such as the content of your emails, other private communications or files in private folders), when we have a good faith belief that doing so is necessary to protect our customers or enforce the terms governing the use of the services."
http://www.techrepublic.com/article/windows-10-violates-your-privacy-by-default-heres-how-you-can-protect-yourself/
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #26 on: 11 October 2015, 22:50 »
Bit the bullet and went for it the other day, got to say I'm quite happy with it so far...
Only problem I had was the built in mail client trying to send emails from my old email address but a quick search on google found the solution, a registry entry change and restart and all was good :afro:
Using this monitor as a 2nd screen for the Xbox One has been a treat too
Offline VWDoesItBetter
« Reply #27 on: 27 November 2015, 08:42 »
I realise I'm late to this conversation, but just felt like adding that I did the upgrade and I'm satisfied. I'm not blown away by it, because I don't see extreme changes, but it's functional and looks good. I'm sure there are features that I haven't discovered yet, but it wasn't a massive change like Windows 7 to Windows 8 was.
