Author Topic: My Paranoid Ramblings: How Secure Is My Car?  (Read 3277 times)
Fielder5757
Re: My Paranoid Ramblings: How Secure Is My Car?
« Reply #10 on: 20 September 2005, 14:06 »
Make sure you have a file on hand when you do, some areas of the door handle have to be shaved back to make them fit better. I have them on my car and havnt had a break in since/
Offline Mr Blue
« Reply #11 on: 20 September 2005, 14:11 »
was gonna say snap off steering wheel.
MK2 bonnets can be opened with a long screwdriver. Get a bonnet switch connected to your alarm so when the bonnet opens the alarm sounds. or weld in a small plate so that the screw driver cant reach the bonnet mechanism.
If the theif gets in your bonnet then he can dissable the alarm sounder if he is really good and take his time
Offline mookie
  • Geordie ABF!
« Reply #12 on: 20 September 2005, 14:11 »
Anyone got a link to a good guide for doing this job? The one I found is a tad vague I think.
Also, I've read up about Slim Jims or some such thang. Again, anyone got a decent link for fitting 'em?
Offline gibby
« Reply #13 on: 20 September 2005, 14:13 »
I can recommend the armour door plates from Euro Car Parts but they're not cheap at about £45 but I will say they are good, really heavy duty and actually look quite good imo. You will get 10% discount if you speak to Stuart at the Leeds ECP branch (see deals and discounts), but this discount is only valid at the Leeds branch.
Others may have got them a lot cheaper and I guess they will tell you how good quality they are.  :undecided:
......now officially dubless.
Offline tobz.
« Reply #14 on: 20 September 2005, 14:24 »
I have had a set of the £10 plates in the past and they were cr@p, distorted the doorskin like hell around the handles and stuck out quite a bit. Having said that, about a week after I fitted them I noticed somebody had had a go at one and failed to get in (just made the plate even more of a mess) so I guess even the cheap ones do the job. The set I have now are the £40-odd ones and they do look miles better, although as Fielder said you do still need some small files handy if you're going for the perfect fit.
You got any pics of your dad's split ?
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« Reply #15 on: 20 September 2005, 14:26 »
I've got a set of the proper door armour plates as Gibby stated - going for £20 for the the two... was going to use on old skool cab.. but not required now..
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline tobz.
« Reply #16 on: 20 September 2005, 14:27 »
A slim jim is a tool used by thieving scum wanting to make off with your pride and joy. It's a long flat piece of metal with a hooked end, it's slid between the doorskin and the glass and can be used to pull up the lock mechanism. You can have plates fitted inside the door to shield the mechanism from this kind of attack. I'm afraid I don't really know anymore details though.
Offline gibby
« Reply #17 on: 20 September 2005, 14:35 »
£20 for some heavy duty puppies is a bargain.
Offline Madone_si
« Reply #18 on: 20 September 2005, 14:54 »
Yep.. I'm starting to have a clear out and I need to just clear the garage mate... will put up full details later in the week under for Sale section...
SOLD - BLACK SOY 92
Offline BobbyT
« Reply #19 on: 20 September 2005, 19:31 »
delocked mine, already had the armored door plates, had a disk lock from my last car and fitted a cat 1 alarm + imob! still worry though!
