Author Topic: abs ecu  (Read 4350 times)
Offline danmusic24
Re: abs ecu
« Reply #10 on: 27 May 2015, 22:15 »
sounds good will check it out and let yer know??
can i get part number from ecu with it in place?
Offline hardmonkeys
  • Moderator
Re: abs ecu
« Reply #11 on: 28 May 2015, 10:41 »
Should be able to,
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline SimonG
Re: abs ecu
« Reply #12 on: 28 May 2015, 11:35 »
Just look underneath the ECU and pump, a camera phone is invaluable here.  Should start 3A0 907 XXX X.
And if you ever remove the ECU from the pump, use the correct E5 socket to avoid chewing the bolt heads.
  Mk3 Anniversary GTI 16V, Mk2 GTI
