Author Topic: keyfob battery  (Read 5461 times)
Offline monkeyhanger
Re: keyfob battery
« Reply #10 on: 31 May 2015, 13:54 »
Just had a key fob battery warning light on the dash. Quite surprised as the car is only 19 months old and done 19,000 miles. Just goes to show you how much the KESSY system talks to the key compared to standard remote central locking. Must drain the battery (which isn't a tiny one either).
I swapped the battery with the spare key. Can't risk the key dying and not being able to start the car  :shocked:
Amazed your battery lasted that long - I thought most keyless people got around 4-6 months from their battery. Most traditional key users should see around 3 years from the battery if they only use the one key all the time.
Offline CraigW
Re: keyfob battery
« Reply #11 on: 31 May 2015, 14:04 »
Mine is 22 months old and no sign of the battery running out.
Offline C2K
  • Northern Monkey
Re: keyfob battery
« Reply #12 on: 01 June 2015, 20:16 »
Mine needed  a new one this weekend. Got 2 starts warning me about it before it was flat as a pancake. Luckily car was unlocked as I was at work. Only a year and 2 months old,  no keyless entry here.
5 Door Night Blue GTD
Dynaudio, 19" Santiago Alloys, Adaptive Chassis, Leather Pack, Winter Pack, Reverse Camera.
Bianca White 306 Rallye (Supercharged + Caged) : Melting Silver F54 Mini Clubman Cooper S
Offline itavaltalainen
Re: keyfob battery
« Reply #13 on: 01 June 2015, 21:22 »
You can always start the car and get into it - even if battery is flat out dead.
Take cap off lock and just open using the key blade. To start hold the key where the immobiliser reading coil is (that is where key barrel normally lives), it then uses RFID transponder in the key rather than the battery driven active circuit to de-immobilise.
