Author Topic: Part number for genuine LED rear lights (non dark)  (Read 4306 times)
Offline GTI2014
Re: Part number for genuine LED rear lights (non dark)
« Reply #10 on: 31 May 2015, 11:24 »
Hi All,
Yes also ordered from Xenonz and awaiting delivery (their new shipment arrives next week) - with regard to coding, I was looking for some advice - I have a 2009 with OEM Xenons  and have been told to use the Golf GTI ROW option for byte 18, but also heard that this option may work and result in side effects such as dim side lights?
After much research, I see that others have used 04 and 15 in byte 18 - any assistance much appreciated,  Thanks.
Offline mustard
  • Mk7 R
« Reply #11 on: 31 May 2015, 11:59 »
Here is some information I posted in the Xenon retrofit thread, I have a 2010 GTI with Retrofitted Xenons (without LEDs) and have used this table to get the correct operation.
I have retrofitted OEM Xenons, but without the LEDs, I used 15 in Byte 18, I found the information on this Vortex forum:
MJ2009 with BCM (03xx software)
Encoding   VCDS Byte 18 = 04
Lights go out at the tailgate opens   NO
Error message MFA   Rear fog lamp with Resistance: No
Problem with front parking light (weak light)   NO
LED tailgate light up more when braking   YES
MJ2010 with BCM from KW22/2009 (Software 0537, 0541)
Encoding   Halogen VCDS Byte 18 = 15   Xenon VCDS Byte 18 = 43
Lights go out at the tailgate opens   NO   Update on 0575 / 6 *
Error message MFA   NO   Update on 0575 / 6 *
Problem with front parking light (weak light)   NO   Update on 0575 / 6 *
LED tailgate light up more when braking   NO   Update on 0575 / 6 *
With MJ2010 / BCM 2011 from KW45/2009 (0573 & 0575 Software / 0576)
Lights go out at the tailgate opens   YES   YES
Error message MFA   NO   NO
Problem with front parking light (weak light)   NO   NO
LED tailgate light up more when braking   NO   NO
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #12 on: 31 May 2015, 13:17 »
I have a march 2010 with xenons.
After much technical assistance from Dana from ross-tech the makers or vcds/vagcom. The only code we tried that worked fully on mine was 15 the 43 code caused some strainge auto lights behaviour. 04 caused dim sidelights.
« Last Edit: 31 May 2015, 13:20 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline GTI2014
« Reply #13 on: 31 May 2015, 16:22 »
Thanks guys for the replies, so "15" looks the best option, many thanks again  :smiley:
Offline Screech
« Reply #14 on: 01 June 2015, 20:14 »
I've been thinking of taking my standard colour LED rear lights off of mine.
If any of you want them then I'll seriously consider it.
£350 plus postage.
Offline SunnyGTI
« Reply #15 on: 01 June 2015, 20:25 »
Hi. Yeh I am interested. I will send you a PM :)
Offline Screech
« Reply #16 on: 01 June 2015, 20:51 »
On a side note, I've checked the part numbers against mine, and it seems the standard led and the r LEDs have the same part numbers... :/ confused.com
Offline mike.
« Reply #17 on: 01 June 2015, 22:44 »
The last letters should be different as below.  (01.03.2011>>)
GTI Rear LEDs
5KO945096 P
5KO945095 P
5KO945093 AH
5KO945094 AH
R Tinted Rear LEDs
5KO945096 Q
5KO945095 Q
5KO945093 AJ
5KO945094 AJ
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
