Author Topic: Scratches on rear lights - PlastX?  (Read 5688 times)
Offline Dean0991
Re: Scratches on rear lights - PlastX?
« Reply #10 on: 15 June 2015, 21:21 »
Use 1500 grit wet and dry then over the top of that use 2000 grit dry off and buff till it's clear. Will look good as new once finished. Tape off the edges 1st so you don't touch the paint work.
Can do the same on your headlights if they have started to fade. Try it you will be impressed
