Author Topic: 1.8T smoking?!  (Read 3202 times)
Offline markallen
  • AUM 1.8 20v Turbo 150bhp for now ;)
1.8T smoking?!
« on: 17 April 2015, 10:09 »
Okay so my old golf is smoking it's nuts off! I haven't been using it as much over the last few months and thought it could have been that which has caused a little smoke, however...it's still there? When I drive it seems fine, stop at a junction or lights and it's as if someone has done a burnout! Can't she sod all sometimes! It's the similar colour to cigarette smoke if that makes sense?  :undecided: Please could someone shed a little light on this please? I have just started getting interest back in my Golf but loosing faith once again! Thanks Mark
Golf Mk4 GTi Turbo, R32 front bumper, Lowered on ProSport Coilovers, Bora illuminated vents, Armrest, Heko wind deflectors, Aluminium vinyl trim.
Soon to be added, FMIC, 3" exhaust, Remap..oh and new turbo :(
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 1.8T smoking?!
« Reply #1 on: 17 April 2015, 18:13 »
Oil is being burnt and you're also saying you need a new turbo in your sig.... Coincidence? :wink:
Offline Dalo Harkin
Re: 1.8T smoking?!
« Reply #2 on: 26 April 2015, 07:09 »
White smoke is coolant blue is oil, which one you topping up more? Head gesket most likely if its coolant and oil seals in the turbo if its oil
Offline golf-sib
  • Турботазик
Re: 1.8T smoking?!
« Reply #3 on: 03 May 2015, 01:58 »
White smoke can still be oil, not always with a blue tint, the smell is distinctive if oil is unburnt. My TT turbo failed (hybrid - 320bhp) and that was white smoke.
Golf went Wednesday, oil issue, was white smoke, can smell oil so distinctly, it's like when you decat you get that smell of petrol except its an oil smell.
As for oil issue, work backwards. Check turbo over, if its fine, no signs of being caped in oil and oil is in manifold you know its not the turbo, step two would be compression and/or leak test that would rule rings or valves out. If not that then its more than likely a PCV blockage, also known to cause oil burning issue and sapping oil into the intake and causing smoke. (or work the other way, whatever is easiest to do first, mechanics is a process of elimination at times).
Look out for other signs, if you're not using any coolant and the smoke is white then you know it's not coolant or a head gasket issue.
My golf issue which happened wednesday i thought was the turbo, turned out to be a blocked breather as catch can was full like a daft twit and it was sucking up that gunk into the TIP burning out oil in the process.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline mike1990
Re: 1.8T smoking?!
« Reply #4 on: 04 May 2015, 22:22 »
Spot on
