Author Topic: PR Option Codes  (Read 11194 times)
Offline BigD
PR Option Codes
« on: 03 April 2015, 08:34 »
Morning,
I was checking the PR codes listed in the book for my car and none of the options I have are listed as PR codes. Its not a case of the car not having them e.g. it is evident there is a rear view camera as it comes on the screen.
In previous VAG motors all the options on the car had a PR code.
Has anyone else noticed this?
PR code Checker http://igorweb.org/equidec/
Offline dv52
Re: PR Option Codes
« Reply #1 on: 03 April 2015, 10:18 »
Morning,
BigD: Hi.
 The PR number from VW for just the rear camera (i.e. as a separate item without linking it to something like parking control)  is: Code=7X9   Group=EPH
If the rear view camera is linked to parking control the PR number is Code=7X7    Group=EPH
I've put a complete set of PR numbers in a spreadsheet on dropbox which you can download if you want. The PR numbers in my spreadsheet worked for decoding the Importer sticker on my mk7, so it should be OK  for your car
https://www.dropbox.com/s/kaolddlmukqvil7/Golf%20vag-option-codes_2.xlsx?dl=0
103TSI Highline ROW (my13)
Offline BigD
Re: PR Option Codes
« Reply #2 on: 03 April 2015, 11:29 »
Morning,
BigD: Hi.
Thanks, I am not looking for the PR codes for the options per say, just the fact that the PR codes are not listed on the build sticker.
For example, all the PR codes from the build sticker are below (none of the options I put on the car are)
B0N = Component parts set, complying with vehicle type for Great Britain, various parts
CC1 = Alloy wheels 7.5J x 18
G1A = 6-speed automatic transmission
H7D = Tires 225/40 R18 92Y xl
J0T = Battery 360A (69Ah)
D80 = 4-cyl. gasoline engine 2.0 l/169 kW 16V turbo FSI, homogeneous Base engine is TA2
Q4P = Sports front seats
1AZ = Electronic stabilization program (ESP)
1G9 = Space-saving spare wheel for temporary use, radial tire (5-hole)
2FW = Leather trimmed multi-function sports steering wheel w/ Tiptronic
1NL = Covers for alloy wheels
5RV = Right exterior mirror: aspherical
5SJ = Left exterior mirror: convex
TP6 = 4-cylinder gasoline engine 2.0 L unit 06K.A
0BF = Rear stabilizer
3S0 = Without roof rails/roof load rack
3U1 = Foldable trunk cover
QI6 = Service indicator 30,000 km or 2 year ( variable )
I8D = Standard radio (Gen1)
8GV = Alternator 180 A
8ZH = Antenna for AM/FM reception, "diversity"
1KJ = Disc brakes, rear
1LJ = Disc brakes, front
G06 = Front shock absorption
7MM = Emission standard EU6 plus
0Y1 = Standard climatic zones
4UP = Drivers and front passenger air bag with knee air bag and front passenger air bag deactivation
4X4 = Side air bag, front and rear with curtain air bag
4R4 = Power windows with comfort operation andcircuit breaker
4K3 = Radio remote controlled central locking operated from inside and safe securing
N2T = Fabric seat covering
5MR = Decorative inserts
8RM = 8 speakers (passive)
2JG = Body-colored bumpers
E0A = No special edition
0AE = Front stabilizer
2UC = Sports version
2G7 = Filler neck module 1 with insert
1JE = Rear sports shock absorption
L39 = Suspension range 39 installation control only, no requirement forecast
0YD = Weight range 4 installation control only, no requirement forecast
Offline BigD
Re: PR Option Codes
« Reply #3 on: 06 April 2015, 15:44 »
No one...?!
The only options I can't visually confirm is the climate screen and rear air bags...
Also there is no PR sticker on the boot? I queried this at the time of collection and the golfs in the show room were the same?
TIA
Offline kevinm
Re: PR Option Codes
« Reply #4 on: 06 April 2015, 20:31 »
The sticker does not list all of the or codes on the car. You can get the full list of pr codes from a dealer. I have my list posted in my build thread.
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
