Author Topic: Kenwood/Garmin Nav Upgrade for Mk7 anyone?  (Read 41233 times)
Offline DougL
Re: Kenwood/Garmin Nav Upgrade for Mk7 anyone?
« Reply #40 on: 29 March 2015, 18:39 »
Yes you can see all the units in the video at the start to this thread.
Tornado Red GTI 3dr manual
Previous Golfs Mk1 GLS and GL, Mk2 GL and Driver, Mk3 GL, Mk4 GT TDI, Mk6 TDI (and a Mk2 Scirocco 20 years ago)
Offline Mark V GTD
« Reply #41 on: 30 March 2015, 11:01 »
Thanks Doug - totally missed that!  :rolleyes:
Offline Yumraaj
« Reply #42 on: 07 January 2017, 11:46 »
Im also looking for a satnav in my Golf as well but not sure which is the best one to go for.
I have asked several places including my local vw and they are willing to fit it but some of them are asking for £699 which i think is quite high really.
I actually found a place where they claim to fit a genuine vw Discovery Media pro but the price is doubled...£1400 and i will to travel for 2 hours to get there then 2 hours back lol.
So guys which one would you recommend?
Has anyone managed to update their unit via SD card? If so how does the IMG file looks like? Does the file needs to be unlocked via some sort of key?
Thank you lots for any help.
Offline Yumraaj
« Reply #43 on: 28 March 2017, 10:34 »
Just to let you guys know that I have got Kenwood GVN60 fitted and it works fine.
It was fitted by my local VW garage and gave them a SD Card extender which fit in the satnav module and then secure by a piece of velcro in my glove box. The satnav itself is hidden away behind the glovesbox so there are wires anywhere to be seen.
The TMC is free for Life which is great but a bit hit & miss with coverage.
I have also managed to update my maps (2017) via SD Card including adding speed cameras as POI.
Anyone knows how I can improve my TMC signal? The FM antenna is tucked around the A frame of the car.
Any suggestion please?
Thank you all.
Offline fredgroves
« Reply #44 on: 28 March 2017, 11:21 »
I thought the FM antenna was in the rear window?
If not, maybe it actually has two antennae - the older golfs did I believe and had two connectors which it dynamically swapped between to get the best signal.
Offline Yumraaj
« Reply #45 on: 28 March 2017, 11:29 »
No mate, the antenna is short and wont reach the rear window  :sad:
Offline Yumraaj
« Reply #46 on: 28 March 2017, 11:46 »
Do you think if i splice open the cable and secure it to the chassis of the car will help? Thanks
Offline fredgroves
« Reply #47 on: 28 March 2017, 12:32 »
No, I meant that the mk7's fm antenna is in the heated rear screen... The antenna cable behind the dash runs to there.
Offline fredgroves
« Reply #48 on: 28 March 2017, 14:27 »
Ahhh I see what you mean now - the Kenwood has two antenna feeds - you've got the radio one hooked up and they provide a seperate aerial you fit round the door frame for TMC.
I bit of google suggests that the reception is poor though just as you describe.
Seems the answer is to get a Kenwood aerial splitter and connect both aerial connections to the actual in car FM aerial which is as I say the heated rear screen.
Give that a whirl.
Offline Yumraaj
« Reply #49 on: 28 March 2017, 23:05 »
Hi Fedgroves,
I think I will do just that, but can you please help me with this?
Which one is the FM port and where do you think I can one?
https://ibb.co/jR9A5a
https://ibb.co/ik4MBF
I am a bit confused as well if i need a ken wood splitter or do i need one that will split the VW antenna?
Sorry too many questions mate.
Or is it easy enough if connect the actual TMC cable to the original VW FM antenna?
Thanks
« Last Edit: 28 March 2017, 23:09 by Yumraaj »
