Author Topic: Wheel bearing recommendations  (Read 5296 times)
Offline boneybradley
  • Back in a Mk3...
Re: Wheel bearing recommendations
« Reply #10 on: 28 March 2015, 16:37 »
Ain't there a different heavy duty bearing for cars with 18" wheels (25th anni, R32, Audi TT etc)?
That's possible, Bearings are same size but it's a possibility they are more heavy duty?
(I know with the Mk3 the standard and GTi bearings themselves are the same or have the same markings etc and it is just the sundries that are different)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 30 March 2015, 10:00 »
I couldn't find any different bearings listed on ETKA...
  • Back in a Mk3...
« Reply #12 on: 30 March 2015, 19:26 »
Mine shows GTI 25th as bearing kit 8L0 498 625 and the standard mk4 as 1J0 498 625
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 30 March 2015, 19:38 »
curiouser and curiouser lol
VW BUSH
« Reply #14 on: 30 March 2015, 19:57 »
lots of factors, size and shape of housing mostly with load being defined by speed an load.
If you can be bothered the whole part number system is explained in the links below
http://www.skf.com/binary/tcm:12-66347/457013_tcm_12-66347.pdf
http://www.skf.com/binary/tcm:12-144662/Catalogo%20Cuscinetti%20Ruota%202013_tcm_12-144662.pdf
Offline Scott D
« Reply #15 on: 01 April 2015, 01:41 »
I need do the bearings on mine soon..
As it is a 180 late version is the Anni/R32 kit needed rather than normal? Had a quick look on ECP and same for both but would rather have a more heavy duty bearing as on 18" wheels and quite low.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Mr_Orange
« Reply #16 on: 01 April 2015, 06:59 »
Heavy duty bearing comes with a large torx bolt, standard comes with a nyloc nut. Depends which driveshafts it has fitted.
Build thread clicky
  • Back in a Mk3...
« Reply #17 on: 01 April 2015, 12:50 »
Message me your reg and I can check which are correct fit (and give a quote on them)
Offline pickles
  • Next!!!
« Reply #18 on: 03 April 2015, 10:59 »
ive used these and had no problems, good price for a pair as well
http://www.ebay.co.uk/itm/191211002471?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
