Author Topic: Bluetooth installed but problems, help needed  (Read 6428 times)
Offline Obbzi
« on: 01 March 2015, 21:54 »
I have an RNS315 head unit and finally fitted the Bluetooth module today and went to somebody to get it coded with Vagcom. Got it paired to my iphone and synced the phone book and displayed on the dash and I can make calls using the MFSW but I cant answer calls!
At first the phone button on the steering wheel wasnt working but some coding was done and it now works but I cant answer incoming calls! I can make outgoing calls (through contacts or last dialled numbers etc) but if someone rings me I cant answer it!
Anybody have any help please?
I also had a few other things done, alarm chirp, cornering lights, footwell lights on etc and if anyone else can think of some good things let me know!
2008 R32 DBP gone. 2008 GT TDI going 2009 GTI coming soon!
Offline dubber36
Re: Bluetooth installed but problems, help needed
« Reply #1 on: 02 March 2015, 08:27 »
The RNS315 has Bluetooth built in. Are you saying you have fitted a separate module as well?
Regarding things to add using VCDS, the big digital speedo is a good one. Go into Instruments and select ROW (Rest Of World) This will change the MFD units into Kilometers and Litres, but you can change this back to Milles and Gallons in the MFD. Then go into MFD Data, tick Digital Speed and untick Alt Speed. The small KPH speedo will be replaced with the external temperature and the big speedo will be in the MFD data.
If you go abroad and need the KPH speedo, just re-tick Alt Speed and it will come back.
Offline Obbzi
« Reply #2 on: 02 March 2015, 09:33 »
Thanks Dubber I will get that done next time  :smiley:
Offline Obbzi
« Reply #3 on: 02 March 2015, 09:34 »
The bluetooth module I installed is 7P6 035 730J (SW:3200 HW: H15) not sure if this is anything to do with it?
Offline dubber36
« Reply #4 on: 02 March 2015, 11:37 »
Offline Obbzi
« Reply #5 on: 02 March 2015, 12:14 »
Only certain models of the RNS315 have Bluetooth built in, apparently mone doesnt so I needed the module
Offline J400uk
« Reply #6 on: 02 March 2015, 18:04 »
Yep not all of them have it built in. Mine doesn't so I'm using a 9W7 Bluetooth module with it.
Here is the list if you want to double check for yours - http://www.briskoda.net/forums/topic/287901-amundsen-bluetooth/?p=3421360
2015 Golf GTD 2.0 TDI 184 PS 6-speed DSG 5 Door Tornado Red
Offline ajmoir36
« Reply #7 on: 02 March 2015, 18:39 »
What button are you pressing to answer, the ok one on the right?
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Obbzi
« Reply #8 on: 02 March 2015, 18:48 »
Trying the Ok button and the phone button
Offline ajmoir36
« Reply #9 on: 02 March 2015, 19:18 »
Interesting... could it be an iPhone issue?
