Author Topic: Things that just arn't working properly...  (Read 6714 times)
Offline p3asa
Re: Things that just arn't working properly...
« Reply #10 on: 26 February 2015, 09:59 »
....................and the mpg is the same as it was when you left it 8 hours ago, resets just as you move off.
I'm sure mine is the same.
Offline Mohsin
« Reply #11 on: 26 February 2015, 10:11 »
I know you can definitely use the 'old style' not adaptive cruise control. I remember seeing the setting...but can't remember how off the top of my head. I'll post back later on with further info.
2014 Golf GTD
2010 Civic Type R Mugen - Sold
2004 Leon FR PD150 - Sold
Offline Gingernick
« Reply #12 on: 26 February 2015, 11:23 »
it remembers the sport/eco/normal settings on my gti
3dr Gti, manual, tornado red, performance pack, dynaudio. gone now
5dr GTi, manual, red, Performance pack, dynaudio
going
5dr Gti, Manual, performance pack , indium grey (for a change!)
Offline ajmoir36
« Reply #13 on: 26 February 2015, 12:29 »
The only quirk I had from the mk6 was turning the mirror knob failed to fold out the mirrors occasionally and if you got in and turned the ignition call all too fast it used to bing ESP fault and then clear it.
I have read others having heavy downshifts, so just figured that's normal. The keyless thing is just pants really.
Obviously I have scanned it on multiple occasions no fault codes. If I didn't buy used I would not have ordered keyless at all. There must be others that have had weirdness with the keyless system.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline bri
« Reply #14 on: 26 February 2015, 13:18 »
My new GTD does,nt do the needle sweep on every start either?  I'm non keyless btw.
It's something I've been meaning to ask on here for a while as to the reason for this.
MK7 GOLF GTD .CARBON STEEL GREY MET.S+S
Offline corgi
« Reply #15 on: 26 February 2015, 14:00 »
Isn't it something that can be set by VCDS? So the fact that it doesn't do the needle sweep is not s defect as such, it just hasn't been set to do it...
There's thread about VCDS things...
Corgi
Offline Mark V GTD
« Reply #16 on: 26 February 2015, 15:46 »
It should do it - so if it isn't doing it then it needs rectifying!
Offline fredgroves
« Reply #17 on: 26 February 2015, 16:51 »
Maybe the car was tweaked by the previous owner...
I doubt if the dealer did some kind of factory reset on it - if thats even possible?
Offline ajmoir36
« Reply #18 on: 26 February 2015, 17:10 »
I would say mine misses every tenth sweep or something. Not really counted.
« Last Edit: 26 February 2015, 17:12 by ajmoir36 »
Offline bri
« Reply #19 on: 26 February 2015, 20:40 »
i should have made that more clear. the needle sweep works on the car alright, its just that it does,nt sweep every time i start, seems not to bother sometimes. it may not sweep sometimes if the keys are left in the ignition between starts.
i cant seem to find a pattern to it.is it just on first cold start up maybe?
is it definitely meant to sweep on every single start up ? car is brand new btw.
