Author Topic: hardmonkeys - mk3.5 Cabrio 2.0 8v auto to 2.0 16v manual conversion  (Read 249300 times)
Offline hardmonkeys
  • Moderator
Thanks pal, not sure on the colour yet, it'll be staying this colour for now, who knows what will happen in the future lol
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'0 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
Offline hardmonkeys
  • Moderator
Engine still not starting, I have changed the crank position sensor and ignition coil, but still nothing.
Will scan in the morning again see what comes up
Offline lemski
  • 16v
Is the crank sensor that came outalright?
Can you heae fuel pump prime.
Checked for a spark?
Offline hardmonkeys
  • Moderator
The wiring on the old crank sensor was brittle and frayed, the fuel pump does prime, not checked for spark as yet, but have the rest of the week free to do some investigation, battery was going flat so will give it a charge tonight and have another go tomorrow.
Offline hardmonkeys
  • Moderator
Spent the week replacing different part/sensors trying to find out why it wasn't sparking, speaking with some of you people on here and finally (maybe) getting to the bottom of it,
Replaced:
  • HT leads
    ignition coil X2
    Plugs
    Ignition switch
    Crank Sensor
    Coolant Temp Sensor
Finally when I was at the end of my tether, I pulled the ECU to rule it out I spotted this..
So, this is where it lies, I think...I reckon the old loom melting has caused this...so on the look out for a new ECU, or a decent repair
Offline hardmonkeys
  • Moderator
Found a ecu on eBay for starting price £10, figured I'll get it, see how it goes, and if it's a duffer, it's only cheap, anyway I bidder up to £20, ended up winning it for £13.50 and £6 postage. BARGAIN!!
Just hoped it worked, researched programming the Immob to it when it arrive and hopefully it works.
Few days later, think it was Friday it came through..I fitted it and programmed it...fingers crossed!!
IT WORKED!!!! it runs like a dream! So I began slowly putting it all back together..bled the coolant, and power steering and bled the clutch, and took it up and down the road To get it up to temperature, I had a slight leak on the coolant, so replaced the hose and jubilee clip, now it seems all good.
I have no indicators on the left hand side, hazards work just not the indicators, will have a look into that later, I'm in work later tonight, so having a rest from it all now.
Offline lemski
  • 16v
Fuse or stalks. Glad its nearly back together
Offline hardmonkeys
  • Moderator
Sorted the indicators, I nicked a wire put the dash back in, soldered back together, and all back to normal  :smiley:
Few trim panels to put back on, and bumper back on, the 'should' be ready for MOT. It needs a new screen, but struggling at the min, as I'd dropped the car to fire and theft while it was off the road...thus removing my glass cover!!! Adrian Flux won't let you upgrade the policy again until renewal...just in case people upgrade then a few days/weeks later all of a sudden have a cracked screen...So it's priced at £210... Trying to get cheaper
Offline lemski
  • 16v
Thats an expensive screen. Surely you can get one cheaper though bud
Offline madmanmart
I've had one done at £100 fitted.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
