Author Topic: recommened me a foam lance please  (Read 6748 times)
Offline Booth11
Re: recommened me a foam lance please
« Reply #10 on: 10 February 2015, 20:05 »
Good luck!  You only need to use about an inch of snow foam and top up bottle with lukewarm water.  It's trial and error with the nozzle and thickness adjusters but once you've used it a few times you'll get to know your preferred settings to get the best foam consustency.  Valet pro  is a bit thinner than some foams but more effective imo.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline lee1989
« Reply #11 on: 10 February 2015, 20:16 »
Thanks mate think i might need it  :smiley:
A little thicker foam than ive been getting and ill be happy, ive heard good things about valet pro which is next on my list to try but currently im using auto finesse avalanche which ive also heard is good  :grin:
Offline Snooze
« Reply #12 on: 16 March 2015, 18:02 »
My new lance just arrived from clean your car and blimey thats a piece of kit. It must weigh a kilo!
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline Booth11
« Reply #13 on: 16 March 2015, 18:10 »
Congrats on your new purchase  :laugh:  You can see where your £40+ has gone when you see it in the flesh and you can probably also appreciate why they do a much better job than the karcher one.
Takes it a bit of trial with the dilution and spray adjustments but you'll get to know what is best, after a few goes.  Best advice is to make sure you run clean water through it, when you've finished each time (via the pressure washer), as they can clog easily with dried shampoo if you don't.  Enjoy foaming.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Snooze
« Reply #14 on: 16 March 2015, 18:44 »
Cheers booth. Hope it does what it says on the tin!
Offline KyleB
« Reply #15 on: 18 March 2015, 10:18 »
My 2ps worth of advice is that if you put about an inch of the foam in the bottom of the bottle and fill it with warm water you get nice thick results. Also don't forget to twist the valve on the top to change the thickness.
